Dug out my LP Studio so a colleague could take a look at it and make it playable again. Tweaked the truss rod, raised the bridge to a more sensible height and now it's fine EXCEPT for a buzzy D string, which seems to only happen when the string is played open - suggesting a problem with the first fret or maybe the nut.
Nut looks fine, no excessive wear at the D string, nor does the D seems to sit lower in the nut than it should.
However, the first fret looks to my amateur eye like it is raised a little in the middle of the fret - i.e. the fret has too much of a radius compared to the board and to the other frets. Is this possible? Is this even a thing?
Assuming my amateur diagnosis is correct, what is the best way to remedy this, and what should I expect to pay a decent repairer?
If it was the fret coming g up at the ends, I'd have a go at gluing it back in myself and clamping it to set, but this sounds more like something I could mess up
If no gap, so the chances are it is buzzing, then a quick simple repair is possible either side of the top nut then mask off - gently drop some Superglue into the nut slot - handy to get a thin string and 'manouvre' the glue into the slot - leave for a day and recut as required - assuming you have a proper top nut file set - If not many techs can sort this out for you - A new nut is possible but this repair can work well
Yes a fret can lift, but unlikely to effect one string alone - they can 'spring' out of their slots and as such it would generally have an impact on 2/3 strings and not one - If you think it has 'sprung out' and there are gaps below the bottom of the fret and the fingerboard, you can try and tap it back in - a lollypop stick, or similar and rest along the length of the fret and gently tap back in - This might or might not work - depends if the fret slot has worn, is to big, or the tangs on the fret can bite against the fingerboard slot to remain seated - They can even re-spring back up - you won't know until you've tried - Option then is to remove the fret and try again with a touch of glue, but I tend to get a tech to look at it for you and replace the one fret - I assume other frets are fine and not causing any issues and no fret wear of any concern
Taking the advice above on board, I am putting my amateurish assumption that is was a lifted fret to one side (as @guitars4you says, it would more likely affect 2 or 3 strings rather than just the one) and accepting that it is the nut at fault.
My colleague tried a bit of tape in the nut slot, just to test out the theory that building the slot up a bit would resolve the issue and... hey presto, it did.
Wouldn't want to replace the nut myself, and don't really want to be paying out money on this right now, so my first step will be to try and build the slot for the D string back up a bit myself - Ed of Ed's Shed fame suggests in his video using layers of Superglue. Other suggestions have included baking soda. Any suggestions from our more experienced forumites?
So are we talking the teensiest spot of glue, like a pinhead?
Only problem now is a buzz on the low E around the 12th fret. Arse.
Have tweaked the truss rod and the bridge height, action is already pretty high, so not really sure what to do next, but that's another thread.
assuming a good set up regarding a sensible action and relief then I suspect one of two things
High fret so fret dress probably required
Slight kink on the string itself - not uncommon - try a new string
It's still a useful technique to know for the refret of a refret or damaged slots that can't be rebuilt easily
Instagram
You can have a small kink in a string that otherwise goes unnoticed under tension except for a hard to figure out buzz making you think you have fret problems.
Loosen the string and run it through your forefinger and thumb and make sure there isn't a kink or bump in the string (no matter how small). If there is a kink or bump, replace the string first and try the guitar again.
If the problem remains you are no worse off for checking.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
