Boss ES-8 question
danlptdanlpt Frets: 12
Is it possible to have some switches saved as a preset, and others as simple on and off for a loop and midi message.
I'd ideally want to run in this configuration:
1- Clean amp
2- DLS MKIII
3 -DLS & TS9 stacked
4 - Clean amp & fuzz
5 - Micro amp ON/OFF for any preset
6 - Timeline patch 1A ON/OFF
7 - Timeline patch 2A ON/OFF
8 - Timeline patch 3A ON/OFF
cheers
  • Yes, but you need to upgrade to the V2 firmware. PC commands can then be added to a toggle, you can also have a second press of the Preset switch to toggle something else, look into the use of assigns. Setting mine up now to do:
    1 - Clean, second press give lead boost
    2 - Crunch, second press give lead boost
    3 - Dist, second press gives lead boost
    4 - Short Delay (on/off) - Strymon TL select patch or bypass
    5 - Big Delay (on/off)- Strymon TL select patch or bypass
    6 - Phaser (on/off) - Mobius select patch and bypass, turn loop 7 on and off
  • danlptdanlpt Frets: 12
    sorry to resurrect a dead post......
    can this also be done with the ES-5?
