Bass playing is hard on my back, anyone have a solution?
RockerRocker Frets: 4985
Played bass for a few hours with my friends last night.  This morning I was crippled and sick with a sore back.  Lower back area.  My bass is heavy, as are all basses, so is there a strap that goes around ones waist -  a strap that pulls the guitar in close to the body to minimize the leaning over that is necessary to see the fretboard?  Hard to describe what I am looking for but some waist strap that works in conjunction with a shoulder strap is what I need.
I cannot be the only person who suffers from back pain after playing the bass.  What solutions are out there to solve this problem?  Thanks.
Nil Satis Nisi Optimum
  • No not all basses are heavy. How heavy is your bass?
    My Jazz weighs around 9lb IIRC, and you can get even lighter than that, especially if you look at something with a smaller body like an Ibanez SR - pretty sure those can be under 8lb which is getting close to typical guitar weight.
  • VimFuegoVimFuego Frets: 15515
    one of them acoustic basses? something like a kala u bass mebbe?
  • KKJaleKKJale Frets: 982
    edited April 2017
    edited April 2017
    A few suggestions:
    - Not all basses are created equal. Some can be light. I have a P bass which is just over 8lbs - similar to a strat or tele.
    - The headstock weight and balance can make a big difference to comfort. It affects the way you hold and grip which may be hampering your ability to see and play
    - Get a good strap. I recommend the Mono straps - wide, chunky and very comfy - makes a big difference
    - Try wearing it a bit higher - I know it's counter intuitive, but it encourages a more upright position.
    - Now this may sound facetious, and I don't mean it this way at all, but if you are prepared to put the time in, playing with reference only to the side dot markers and playing by feel is so much more comfortable
    - Are you playing with your thumb behind the neck rather than to the side? - if you do it gives a natural twist to your playing position which makes it easier to play
    Just a few thoughts to start you off...
  • RockerRocker Frets: 4985
    No idea how heavy my bass is @guitarfishbay, we don't have a bathroom scales so no way of checking it out.  It is an Aria STB and it is significantly heavier than my Epi Les Paul.  I am somewhat disabled, the weight of the bass strains my back, resulting in pain.  I actually felt and looked sick this morning.  This does not happen when I play guitar, even the Epi.
    I started a thread on basschat about light basses - there's plenty out there at the 7lbs and under point - might be worth a swap out?
  • axisusaxisus Frets: 28339
    Old Steinberger cricket bat? They are considered very good.
    Status Streamline?
  • JezWyndJezWynd Frets: 6082
    edited April 2017
    Violin basses are usually around 6lbs. If you want something a bit more regular looking the Club bass has similar weight and build but in a LP shape.
    Thanks for all the replies guys.  Lots to think about.  Over on Basschat, a guy suggested this: http://www.hotroxuk....zPuoaAsgu8P8HAQ
    I will mock it up tomorrow and see if the height [70 cm] and the footrest [28 cm from floor] would suit.
    The Status Streamline looks the biz @axisus but I would expect it is way out of my price league.  Good suggestion though.
  • CarpeDiemCarpeDiem Frets: 291
    If the stool above doesn't work for you, it may be worth checking out a QuickLok stool. DV247 have a keyboard stool. It's £130, but QuickLok products are good. Another option, possibly a bit leftfield, would be a weight lifters belt or a latex type support to protect your lower back. If it's any consolation, the bass players in the two bands I play in both sit down for some of the time, generally on their amps.
    I'm guessing that £1.5K is too much? Bass for sale on the Status forum:
    http://www.statii.com/forum/forum/viewthread.php?thread_id=6309
  • fretmeisterfretmeister Frets: 24364
    Yerp. Lighter bass.
  • ICBMICBM Frets: 72412
    The Hofner Violin Bass type basses are pretty light as JezWynd said. Also not expensive, if you get one of the modern copies - there's a Harley Benton at a barely believable just over £100, although I haven't played one so I don't know if it's any good. The Epiphone version at about double that is pretty nice though. (And it wouldn't surprise me if both come out of the same factory…)
    https://www.thomann.de/gb/harley_benton_beatbass.htm?glp=1&gclid=CLa1ouOMxNMCFWUq0wodbD8L3Q
    https://www.thomann.de/gb/epiphone_viola_bass.htm?ref=search_rslt_epiphone+bass_152095_1
    (The HB has the more complex and vintage-accurate controls, the Epi a simpler 'Jazz Bass' set up.)
    The body is small so they naturally sit closer to you with the neck pointing up a bit, so it's easy to see what you're doing. They do have the slight disadvantage of being a little neck-heavy so they can be less of a relief on your left shoulder than you might expect, but they're not too bad.
  • EricTheWearyEricTheWeary Frets: 16297
    You could look at the Planet Waves Dare strap.
    These were designed for people with back and shoulder problems. I think they were originally made by a small company and Planet Waves took over the design and made them cheap. So they do, apparently, fall apart eventually but they are relatively cheap and seem to work.
    edited April 2017
  • slackerslacker Frets: 2246
    edited April 2017
    A mate of mine has some seriously expensive basses (sei pedulla) and he often uses one of those spirit basses. Through a decent amp they sound great.
    edited April 2017
    ICBM said:
    The Hofner Violin Bass type basses are pretty light ...
    I've found that the violin bass (the cheaper modern type) does have a tendency to roll away and down. A combination of the back shape (a bowl shape) and the placement of the front strap button (at base of neck). The original Hofners have a raised fretboard at the body (like a violin) which allowed the strap to run in front of the body but under the fretboard, thus pulling the bass into the body. Complicated to explain - a picture really is worth a 1000 words...
    I was able to mostly resolve the problem by moving the strap button to the side of the body at the top where the neck meets body. Worked well.
    I'd missed that - that's a better made/ more expensive version of the Dare strap.
    Hohner also used to make The Jack bass which was light and headless but with a more conventional body shape.
