Sporkaster 4
SporkySporky Frets: 28224
I am well aware that I am out of sequence, given that SP5 was completed some 5 years ago.
Sp4 is a Stratele hybid, but (obvs) the right way around - Strat body, Tele appointments. Most handmade too, the fretboard was CNC'd (not by me, but on the machine I eventually bought), everything else by hand.
Birdseye maple neck, not sure what the fretboard is (I'll probably remember at some point - Kingwood maybe?), and it'll have Steinberger gearless tuners. 3-piece mahogany body, 25" scale.
I originally finished the body with a red gelstain and some polyacrylic, but frankly I don't like red guitars so I've sanded it all back and it's now stained black with Chestnut spirit stain. I've also mixed some of the same stain into some Chestnut water-borne acrylic lacquer which will be brushed on. It's very, very black.
Pickups will be a Bareknuckle 'bucker in the neck (I think it's a Stormy Monday) and a stacked Axetec tele pickup in the bridge, mounted in a left-handed bridge with 3 compensated brass saddles. There'll be a teeny active tone control if I can find somewhere to mount the battery.
Pictures will follow; yesterday I cut some long-grain beechveneers on the bandsaw to line the neck pocket - a bit loose compared to the neck.They got superglued in and then trimmed, so they're pretty much invisible now and the neck is rock-solid.
Tomorrow will see more lacquer being applied, and I may start on adjusting the shop-bought scratchplate to better match the body shape. Possibly fretting will occur.
«134
  • BigMonkaBigMonka Frets: 1771
    The tantalising text without photos is most unfair on us readers!
  • SporkySporky Frets: 28224
    I know, and I apologise, but my phone battery is flat. Pictures tomorrow. It looks bloody ugly at the mo.
    edited May 2017
    Here's the neck - drilled for Axetec locking tuners, it turns out.
    http://monkeyfx.co.uk/pictures/builds/SP4/01 neck.jpg
    Body after the old finish was removed, a couple of coats of acrylic mixed with Chestnut spirit stain:
    http://monkeyfx.co.uk/pictures/builds/SP4/02 black front.jpg
    Side shot - I put bodies on these painter pyramids.
    http://monkeyfx.co.uk/pictures/builds/SP4/03 side pyramids.jpg
    Obligatory mock-up:
    http://monkeyfx.co.uk/pictures/builds/SP4/04 mockup.jpg
    The acrylic doesn't self-level as well as the polyacrylic I used to use, so sanded it all back to flat.
    http://monkeyfx.co.uk/pictures/builds/SP4/05 sanded.jpg
    http://monkeyfx.co.uk/pictures/builds/SP4/06 back sanded.jpg
    I did another go. Didn't go well either. Turns out that Chestnut's acrylic doesn't mix with their own stains.
    Stripped it again and I've diluted some lacquer so that it flows better - hopeully it'll self-level a bit now.
  • fretmeisterfretmeister Frets: 24276
    I've always liked the idea of a Stratele. I'll be watching this with interest.
    Need to update with more photos, but the refinish is as complete as I am likely to get it. Black with dark turquoise streaking. I will leave that to fully cure for a couple of days while I get on with the fretting of the neck.
    I went back to my old approach to lacquering - lay on a thin, fairly even coat, then keep brushing until it's dry. That seems to get me a thinner, flatter finish. Then scrub with various grades of turning scourer pad things and repeat until bored or happy with the results. Only takes about 10-15 minutes per coat this way instead of two hours, plus half an hour of getting rid of drips.
  • stickyfiddlestickyfiddle Frets: 27002
    There's a hefty bit of Probett Rocket happening here. I like it!
    I don't think it's a particularly innovative idea, but I've not quite loved any of the implementations I've seen. The Rocket is rather tasty though.
    I'd been thinking about trying to fettle the cheapo Telecaster scratchplate I bought onto this but it turns out I can get some nice brushed aluminium composite stuff for £6 per A3 sheet, at which point I can CNC cut it to fit exactly. It'll take some work to get the design right but I think it'll be worth it.
  • RolandRoland Frets: 8706
    Sporky said:
    ... It'll take some work to get the design right but I think it'll be worth it.
    You mean it will be fun to design and make, and may even look interesting when it's finished
    Y'know, I think I do mean that!
    I've ordered some 3M Dibond-a-like - brushed aluminium either side of a plastic core, 3mm thick in total. That ought to be a lot easier to machine than acrylic or similar.
  • lysanderlysander Frets: 574
    Lovely build ! I'm considering a Stratele myself but the other way around - telecaster body with vibrato :)
    I like the contoured neck access, what's the consensus on the ferrules approach instead of the neck plate - is it strong enough ?
    That's the way I'd like to do mine as well as I like a smooth and not too thick joint rather than a big metal plate but a plate is obviously more structurally sound.
    Btw that fretboard looks like Pau Ferro to me.
    The plate just spreads the load and means less machining to do vs ferrules; the same screws are used so the strength of the joint is exactly the same. Or so I reckon.
    I think the difference is in case of impact the screws would be pulling on the body through the surface of the plate vs pulling into 4 relatively small ferrules in comparison, so more likely to rip up the neck pocket.
    But probably still more solid than a Gibson Les Paul tenon joint :)
    In that instance I can see it might make a difference, but I think with a tightly-fitting neck (as this is now) you'd be hard pressed to snap it off either way.
    You might be right on the fretboard - I bought a small job-lot ages ago, had some machined, kept some as-was. Having checked it's definitely not Kingwood, but could be Pau Ferro or at the dark end of Zebrawood maybe.
    In related news I missed the postie with the scratchplate material, and I seem to have left my fret tang clippers at the old workshop. Progress will resume tomorrow - I did at least get all the fret slots cleaned out and the frets cut to length.
  • WezVWezV Frets: 16676
    reminds me i have my stratele waiting for a refin.  its been various corroded metal finishes over the years so i may strip it back and go vintage.   I made an aluminium plate by hand, but it ain't perfect and could do with replacing
    Bit of an update.
    This is the current state of the body - not a great finish, but acceptable to me at this stage. The neck now fits very snugly.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/01 body.jpg
    On to fretting. Because the fretboard was CNC cut, and the slots milled, the first job is to clean out the slots using these torture implements - the hook lifts out any chips or dust, and the little saw is in case anything needs deepening.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/02 implements.jpg
    Then check with this nifty gauge:
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/03 slot depth.jpg
    This is pretty huge fretwire. Cut into appropriately sized bits with a pair of Cresent compound side-cutters - they have a double-fulcrum thing so lots of mechanical advantage.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/04 frets cut.jpg
    The tang is too long for the slot though.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/04 slot vs tang.jpg
    So next the tang is cut short with the grey nippers, then the slot is filled with Titebond using the syringe and a blunted needle. Wet cloth for wiping up any glue that squeezes out.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/05 fretting stuff.jpg
    I use a Stewmac arbor thingy for pushing the frets in - much easier than hammering and better results (for me at least).
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/07 arbor press.jpg
    First one done. 21 more to go. I spotted here that the end of the neck could do with some tidying, now sorted.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/08 first.jpg
    And all in. Not bad for an evening's work. I also trimmed the ends down with the Crescent cutters, then they'll get filed flush with the fingerboard edges. More later.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/120517/09 all fitted.jpg
  • SeshSesh Frets: 1842
    I really like that fretboard wood.
    Can't sing, can't dance, can handle a guitar a little.
  • JalapenoJalapeno Frets: 6390
    Looking dandy !
    Feedback
