DigiTech Whammy plug?
RicRic Frets: 0
Hi, Which barrel size 9v plug fits the Whammy please? I have many daisy chain plugs but only one fits.
That leads on to my next question: how many different 9v barrels are there for pedals and can UK adaptors be found for non-standard sockets like the Whammy please?
  • JD50JD50 Frets: 659
    edited May 2017
    I have the latest Whammy (5?)it takes s a standard Boss type, not sure about previous versions
    I think there are 3 main types of socket (according to my pedal board anyway), Boss type, old MXR/Rat/Dod male plug, EHX.
    Could be mistaken but I belive MXR are now using the Boss type?
    Also most but not all pedals are 9v.
  • sgosdensgosden Frets: 1994
    edited May 2017
    fairly sure my Whammy 4 needed 12V AC so won't work off a standard daisy chain
    What version have you got?
  • TeetonetalTeetonetal Frets: 7806
    Power requirement is a huge differecne in Whammy versions. The version 5 runs off a boss 9v type connector.
    Version 4 is 9V AC 1.3 Amps
  • I've a Whammy 4, as mentioned above its AC not DC so won't run off of a standard daisy chain. Later models I believe are DC, its worth confirming before you plug in!!
    Don't know about the Whammy but some pedals take the 2.5 size instead of the usual Boss type 2.1.
  • RicRic Frets: 0
    Thanks. Can you get adapters for the 2.5 size please, so that you can use the 9v device with a standard daisy wheel set-up?
  • RicRic Frets: 0
      Ugh, thanks, got version 4. Mind you - the power source works ok, it just means I need a dedicated plug for the pedal. I also have a Budda wah which takes an oversize 9v barrel plug, would there be an adapter for that please?
    I think Maplins might do a converter plug but @ICBM is the man for this kind of thing.
  • RicRic Frets: 0
    Thanks - good thinking - I'll head for Maplins! ;)
  • RicRic Frets: 0
    And thanks to all for help! - Are there 'like' buttons for this forum please? ;)
