it was my favourite sound when I tried a few out, but the price and weight (not sure it the one I tried was neo) put me off
what is the weight in that one?
I believe it's 36lbs so quite ok actually.
The QSC is quite close though after the whole weekend comparing them.
My music:- https://soundcloud.com/hubobulous
I am moving to Helix Lt from a pedal board effect route, and am trying to decide about the amp....?
(currently have a Carr Sportsman and wondering about the FRFR alternative)
Any advice appreciated.....can't test these as they are 200+ miles away from me.
thanks
Jon
A good FRFR will reproduce with some fidelity what the AX8 / Helix will be putting out in regards to simulating different power amps / valves etc. The ones I've been trying so far are also quite lightweight .. the QSC K8 is very light and with the right settings strikingly close to the CLR. The CLR is still light for it's size (36lbs) and reproduces the sounds a bit closer to a real amp in the room (at least to my ears!).
Hope that helps?
Something 50/50 PRODUCES THE MOST WONDERFUL SOUND
