Mini-pedal question
ICBMICBM Frets: 72253
Just testing a few that will be going up for sale…
Why do they all, almost without fail, have the wrong knob as the big one you can adjust easily?
In most cases it should be the volume/level, since that's the one you can't easily affect using the guitar controls or playing technique and are most likely to have to bend down and tweak on the fly.
    You'll like the tube screamer mini then ;)
  • TheMarlinTheMarlin Frets: 7826
    My biggest problem with the mini pedals is their lack of stability. They wobble around on my board.  My mini Rat will spit out the input patch lead.
  • wingo84wingo84 Frets: 42
    That's my issue with my Xotic SL ... sounds amazing tho so I deal.
  • 57Deluxe57Deluxe Frets: 7332
    The other thing with the ones with 'Borrowers' knobs is that when the super bright LED comes on it blinds you so you can't see the settings unless you lay you pick over it to baffle it!
    <Vintage BOSS Upgrades>
    It's my one criticism of @ThorpyFX  Love the pedals
    have them all.. can't see a single dial on a dark stage
  • DominicDominic Frets: 16082
    just put a bit of electricians tape over the led lens to mute the brightness
  • ThorpyFXThorpyFX Frets: 6123
    Sorry about that, believe it or not, I've dialled the brightness right back..... however it turns out new leds are extremely efficient.
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
