I like the idea of "recycling" old amplification equipment. I was given a non-working 1964 Philips reel to reel tape recorder by a friend who thought I might be able to salvage some of the valves.
Long story short, inside it had a single ended amplifier
which was pretty much an AC4 spec with an EZ80 rectifier, EF86 but using an
ECL82 for output. Transformers, mustard caps etc. were all there
and of the right spec. There was miles of very nice solid core wire in it too.
There was no chassis to speak of, it being built "around" the
internal machinery of the tape mechanisms.
I'd seen posted elsewhere that the current Vox Pathfinder
solid state amp can be converted and it does look like an AC4 and very close in
dimensions. Picked up one on eBay for £35. Stripped it out and was ready to go.
First job was to "design" the layout, not too
difficult in such a simple amp and the chassis is quite roomy, so I chose to
follow the Vox placing of the valves with the earth bar in the
"middle" to hang everything off. In practice I needed to use 3 double
tag strips as well. Next was to cut, drill etc. the holes required. To fit the
transformer I had to make it lay down, only having a drill and tin snips that
was a complete pain of a job! The chassis doesn't appear very thick but I
reckon you could build nuclear submarines with it. Working in the "panel" controls was also a challenge as the Pathfinder panel has a lot of holes ... mostly the wrong sizes, wrong shape and in the wrong place!
Once I'd bodged my way through the drilling, and the chassis was ready, it only took a couple of nights to assemble and solder. I comfort myself with the fact that point to point always looks untidy, but I'm about 80% happy with what I did. Only Issue I had on first start was low output which was quickly rectified when I spotted I'd used a 220k instead of a 22k at the EL84. The amp is very quiet electrically, no hiss, even though I used some old CC resistors.
"> you're too kind ICBM!
Of course I didn't mention that I fused the house trying to work out the mains transformer wiring and you sorted that for me ... or that I managed to get a full mains blast while turning the chassis over with it plugged in and touching the mains live! at least I know the RCD in the house works well!
Bandcamp
Spotify, Apple et al
Bandcamp
