Burkey Flatliner Pro pedalboard power supply and Carl Martin Plexitone Still Available! and Reduced
pumkinpumkin Frets: 136
edited May 2019 in FX £
Picked up in a trade recently but not really my thing.
Good condition.
£115.00 including postage (ppg)
 Burkey Flatliner Power supply.  £125.00  posted PPG
 Super versatile power supply offering lots of options.
Specifications
9V DC
5 Outputs 9 Volt DC, 200 mA, short-circuit protected with a current-limitation on 200 mA
12V DC
1 Output 12 Volt DC, 200 mA, short-circuit protected with a current-limitation on 200 mA
3-9V DC
1 Output variable ca. 3-9 Volt ; V = voltage, R = resistance ( 0…20 Ohm)
3-12V DC
1 Output variable ca. 3-12 Volt ; V = voltage, R = resistance ( 0…20 Ohm)
9/12V AC
1 Output 9 or 12VAC*, capacity 1000 mA This output is protected with a 1AT fuse (on the rear panel)
Polarity
All outputs are centre negative
Fuses
1AT:1A-fuse (9VAC output)
230/240V:2 x 250mAT ----- 115/120V: 2 x 500mAT
Mains
230VAC 50/60Hz for European power. Configurable for 120VAC/60hz for US power
Capacity
33 Watts max
Weight
1960 gr
Dimensions
(LDH)233x110x72
Included also are a few cables ,a voltage doubler and reverse polarity cable.
This unit is used but in full working order..
Am struggling with Imgur with pics at the mo so will try again later.
http://burkey.nl/flatliner engels.htm
              http://imgur.com/SSF7Prw ;
  • pumkinpumkin Frets: 136
    midweek bump...???
  • jezzbrojezzbro Frets: 1
    Would you ship that Kingsley Bard to Belgium?
    If so, what's the total cost? (Kingsley Bard, shipping, paypal)
    Thank you for your reply.
    Jesse
    Hi Jesse ... I will get a price for you in the morning and let you know ... thanks
    Bard now sold
    Plexitone still available.
    Think I got something up there to look at  ...... used to be easy to put pics up !!!
  • Do you still have the Burkey pro rectifier?, already have the power supply, just need the rectifier. How much to the UK including p&p  Cheers Terry
    Yes .... Have PM'd you @terrynoakes ;
    Rectifier sold
