How much is a custom neck? Or Gibson GForce compatible neck
thecolourboxthecolourbox Frets: 9806
edited July 2017 in Making & Modding
Hi guys
Out of hypothetical interest really, were I thinking of ultimately doing up an existing guitar to have a new bolt on neck, I think either 24" or 24.75" scale, with a headstock that would fit the set of G Force that I have in my parts box, possibly with an interesting headstock shape, what night the options be?
How much would a custom neck cost if made to this spec? Either from scratch or altering a standard one? I suspect out of my price range but worth an ask
Or are there decent necks available that would fit the tuners? I guess unlikely given the set neck design of Gibsons
More likely would it be a paddle headstock job that I'd have to get drilled and cut to shape?
For context I'm thinking of saving up over time to sort out a fibreglass guitar to get it done properly with a nice neck and pickup so it's as nice as my WezV made one but with less sentiment attached to it, when I have amassed sufficient funds in the Music Gear Pot. It's still fairly hypothetical as I'll probably lose patience with it but worth researching I think.
Cheers all
soundcloud.com/thecolourbox-1
  • guitargeek62guitargeek62 Frets: 4142
    Paddle headstocks are easy enough to find and sort out, but the real question is... why do you want the g-force system? I had one on a Junior for a while and couldn't stand it, it was unreliable and needed frequent manual tweaking.
  • thecolourboxthecolourbox Frets: 9806
    Mainly because I've got them going spare really I suppose but they do seem to get mixed reviews so probably not the best idea, the perceived convenience perhaps isn't accurate. I tune by ear currently though so I'd assume it's probably at least as accurate as that?
     I guess with or without them though I'd still like a funky headstock (which frustratingly i can't buy off the online shelf) so I guess the question would still be the same, as I couldn't do the shaping or drilling by myself
  • WazmeisterWazmeister Frets: 9571
    I had a G Force system, and it was impeccable! Go figure... never had an issue and was actually quite useful in my exotic tuning period !
    edited July 2017
    Yes I do like the idea of suddenly skipping to dadgad and blasting out Kashmir or open A for Robert Johnson blues
    Could I do it easily enough if I bought a decent enough paddle headstock neck? I guess I'd draw on the holes for the tuners and drill them, then draw the outline and use a rasp to chisel it down? I just don't know of I have the confidence to do it
  • underdogunderdog Frets: 8334
    Have to side with you, I bought a junior with them on, very cheap as they were very unpopular, and I love it, the tuners the neck etc all of it.
    The tuners are conveniently, accurate and quick.
    I'd like to try them certainly, I bought them to go on my ill fated DIY SG kit guitar but they didn't fit so never used them.
    Does anybody have any idea as to a good paddle neck I could try? Are the sub £100 ones off ebay/Amazon etc ok? Or do I need to buy a kit then chuck out the rest? or do I need to go more money for a good one?
    Or a bespoke made/adjusted one?
  • RavenousRavenous Frets: 1484
    I always fancied the WD music paddle heads, but they're a bit pricy. CH Guitars do MUCH cheaper ones but I have no idea if they're any good:
    http://www.chguitars.co.uk/necks/full-paddle.html
    (Maybe someone here has tried their stuff?)
    To answer your earlier question, it should be OK to DIY the outline. The shape could just be rough cut with a coping saw and sanded down to final size with a curved block to get a nice shape. (I did this with a cheapo 6-a-side neck to make it a 4+2 type.)
    I think Tropicana has Paper templates on their website which you can print to measure spacing etc...
    The most important thing is that you have a well cut nut.
  • WezVWezV Frets: 16726
    bloody auto correct ;)
    https://www.tronicaltune.com/how-to-check-your-guitar?navi
    :) Yeah, I'm not sure why a Juice company makes templates for tuners, but according to me, they do.
