How to make an IR? "Deconvolving?"
If I understand the basic concept, an IR is made by suirting a known signal (either a pulse or a sweep) into the item to be emulated, and recording the output, then kind of removing that original (known) signal again, right?
And if that's correct, then it is as possible to make an IR of say an overdrive pedal (albeit at a single setting)
Does anyone know what tools might be used to do it, what the steps are and what type of signal to use?
Red ones are better.
  • RolandRoland Frets: 8701
    Easy enough to do, but not particularly useful. Put a known signal into the pedal, and compare the output with the direct signal. You'd get the EQ of the pedal, but not the other aspects like compression and waveform distortion.
  • TimmyOTimmyO Frets: 7410
    Surely the output signal has been compressed and distorted, and captured as such?
  • stratman3142stratman3142 Frets: 2196
    edited August 2017
    My DSP knowledge is a bit rusty but I think basic convolution works because a linear system can be characterised by its impulse response. Compression and distortion are non-linear system characteristics.
    I expect more complex processing could include an amplitude dependency. Is that how a Kemper works I wonder (I'm getting out of my depth now without reading up on it)?
    It's not a competition.
  • PolarityManPolarityMan Frets: 7284
    It's not a huge jump to what kemper do with profiling though.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    True, but it's not uniform across the frequency range. The compression and distortion that you often hear in an amp is frequency dependent. Many amps and pedals are designed to distort more in certain frequency ranges, so they boost those frequencies before distorting, and reduce them afterwards. Hence frequency dependent distortion characteristics. Depending on how the pedal circuit is designed you can get those factors, plus clipping which adds a harsher edge to the sound.
    edited August 2017
    Even if compression and distortion were uniform across frequency (hypothetically) the compression/distortion would still be a function of the amplitude of the input signal (i.e. non-linear). So, I think you'd need to (in effect) take a number of impulse responses of varying amplitude so that you could do some interpolation. That's thinking in the time domain. There may be other approaches in the frequency domain.
    edited August 2017
    The more I think about it, Kemper profiling must be taking account of non-linear characteristics.
    I did a bit of a search and there might be a clue at the link below:
    The link above has another link to what's referred to a 'dynamic convolution'. It sounds plausible but I don't know if it's correct regarding the Kemper.
    It would be good to know if anyone has any info on the theory behind Kemper profiling and whether that relates to the question of the OP.
    Is that not why they use a swept signal rather than a pulse for some IRs?
    edited August 2017
    A linear time invariant system can be characterised by either its impulse or its frequency response. There's a Fourier transform relationship between the two (see link below).
    But, for a non-linear system (e.g. distortion) I still think you'd need to do that characterisation for a number of signal amplitudes.
  • oafoaf Frets: 300
    You can use something like this:
    http://www.voxengo.com/product/deconvolver/
    or for something cleverer look at stuff from Acustica Audio
    https://www.acustica-audio.com/
    They've done something different with Nebula 4 (some kind of additional licencing/training thing I think, I forget the details) but v3 allows you to make your own. There's an article on it in SOS if you're interested:
    https://www.soundonsound.com/techniques/sample-your-gear-acustica-audio-nebula
    Distortion units don't always sample so well, particularly at the more extreme settings.
  • oafoaf Frets: 300
    Here's an article on using Reaper and its included Reaverb plugin
    https://www.soundonsound.com/techniques/reaverb-part-2
