I've got a fairly major problem with my right hand, and am due to see a physio and an osteopath - but in the meantime, playing guitar is a problem. I'm right handed, so this is my picking hand, and playing either fingerstyle or with a pick is a problem right now. I'm hoping that with medical intervention I can eventually sort this - in the meantime, is there a way I can practice left hand stuff, even just chord progression stuff without the right hand?
I know that sounds a bit mad, but I'm open to ideas! I do have a guitar with a Fernandes Sustainer pickup in - tried that, and it is good for things like practicing vibrato, but I'd like to work on chord progression stuff, which it didn't seem ideal for?
Any suggestions - I took a break already for a full week, and it is as bad as before, so I really don't want to stop playing.
(Children also like doing the stumming part but they are generally a bit uncontrollable)
It's also a good excuse to get an ebow.
If I couldn't pick with my right hand I would mute the strings like said above and try to do everything I usually do (jam, train on arpeggios, scales etc.) but using only my left hand and legato notes. It can be a great way to learn legato, kind of like going to a foreign country to learn the language, once you're there you have no choice, so you'll learn pretty fast!
Also, if you can tap, maybe you can try doing that to if you're into that kind of thing.
Hope that helps, cheers!
Max
I'll work on some legato, as suggested!
