Except bass players... ;-)
I do own and sometimes use a "normal" 4x12 but for the last 20 years (minus a few years off) I've been using various bass cabs. Mainly, two flared and ported 2x12 cabs loaded with Eminence Delta bass/PA drivers, but also currently an Ampeg SVT15E.
In fairness, I downtune a lot, use a lot of octave down effects, and have three heads going at it full pelt all the time but standard cabs have just never quite managed it no matter what speakers I use in them.
Anyone else prefer using bass cabs? Any particular reason?
For a long time we had a 6 cu ft reflex cab loaded with a 200W Fane 15 bass speakers and son would occasionally play his Dominator clone (later an HT-20) through that. Not 'dull' at a all! Well, small room so you HAD to be on axis! The speaker was barely being tickled with 15-20W and so it gave a very clean repro of the amp. Not a sound you ALWAYS wanted but good for jazz and such.
Other speaker were available via a crude patch system. V30, 2 V old Goodmans Audiom 12" a Vitavox 12" ex cinema speaker (V sensitive but shrill) Rocket 50(!) and a Celestion 10 in a box that I don't recall the number of!
Donated the Fane cab to the local Labour club.
Dave.
Which probably wins the 'most overkill amp for playing at home' award, but it probably explains why I've never really understood this "too loud for the house" idea. It was certainly capable of incredible volume when it was turned up, but sounded great at a volume you could barely hear in the next room.
Unfortunately it also took up as much space as a very large chest of drawers, and in the end I just didn't really have room for it in the flat.
If want shimmering highs then maybe not, but for low down dirtyness then fill your boots!
