They're actually Haussel Tronebuckers, if that makes any difference.
Readings aside, does my approach seem sound? I should expect the neck resistance reading to half when split...just like the bridge does?
What happens if you tap the polepieces with a screwdriver when the pickup is split - do you get a different noise on each coil? (ie the sound through the amp!) Is it different from when the pickup isn't split?
Pickup selector to bridge reads 5270 ohms (unsplit) and 2650 (split) [same as before, more or less]
Pickup selector to neck now reads 4440 ohms (unsplit) and 2279 (split)
I haven't sprayed any contact cleaner or taken anything apart...although I have done quite a bit of staring at it. So I presume a bit of usage (it's a new guitar) has 'freed up' the push/pull pot...and the neck pickup was permanently split up to this point?
Pickup selector to neck gave 2348 ohms (unsplit) and 2300 (split)
Very slightly higher readings than last time...and I'm sure it varied a little as I wobbled the pickup...although that could be me touching it with bare fingers, right?
Any ideas? I might lift the pickup out for inspection...not that I know what I'm looking for.
If it is that, the only fix is to rewind the coil.
Depending on how the coil split switching is arranged it might be a short to ground though, which could be in the pickup cable and will be fixable by replacing that.
Most pickups that come to me 'requiring rewinds' require a little poking, prodding and insulating and that's all.
