Does it have to be exactly 24 AWG?
Wikipedia tells me that's 0.51mm.
The suppliers I know about are 0.6mm. (Rapid electronics. Maplin etc.) It'll be a bit thicker and stiffer but I'll claim that makes no difference
22m in a mix of colours for under 3 quid:
https://www.rapidonline.com/rapid-22m-single-core-wire-pack-11-x-2m-each-01-0102
thanks though!
Be carefull though , there is a lot of cheap stuff out there , it will be marked CCA - do not get this , it is Copper Clad Alluminium
If you want solid then cat5 , it's mostly sold on 305mtr reels though . Perhaps where you work has some knocking around after having computer points installed ?
Again make sure it is the solid copper and not CCA .
You don't happen to know where to get good quality 3pdt footswitches from at a reasonable price do you ?
