Magnets | Tall 1/4" Diameter Individual Alnico 5 Rods |
Coil Wire | 44AWG |
Lead Wire | 2 Way with Separate Ground for Cover & Baseplate |
Bridge Output | 7.5k |
Neck Output | 7.0k |
The classic 60's jangle & chime - Still that bright, jangly, unique sound a little sweeter, a little rounder than the Low '57.
Bright, tight with great clarity and definition I make my Mid '63 Ric® style replacements calibrated with a slightly lower neck pickup output for good volume balance through the positions though do offer them as a more vintage correct set with matching Bridge & Neck outputs.
The thinner 44AWG wire helps give a little more mid-range than the low output would usually dictate and when combined with the tall, strong 1/4" diameter Alnico 5 rod magnets that protrude through the bottom of the pickup, you get that classic, rich, early/mid '60s sound - with slightly rolled back highs, a little more in the mid-range than the Low '57.
Toaster® pickups from the '50s tended to have the lower 4.8k-5.0k output whereas into the '60s, the output was increased a little to around 7.5k - So with this in mind you can choose which version you'd like. The 5.0k Low '57 version will sound that little brighter, a little lower in volume than the Mid '63 so if you're after the late '50s sound then go for the Low '57. If you're after that early/mid '60s sound then go for the medium output Mid '63. Both have that sweet, bright sound, the Medium output version being that little fatter, that little bit rounder.
> Creamery Handwound Replacement Ric®, Rickenbacker® & Toaster® style Pickup
