It won't affect the tone when the volume is full up.
The problem is that the right value is dependent on the guitar cable as well as the pickups and amp, but .001u/150K is usually a good place to start.
You can also put the cap and the resistor in either series or parallel, which changes how it works, although oddly the right values seem to be about the same.
There's a thread on the Guitarnuts2 forum about the whole treble "bleed" aka pass thing: http://guitarnuts2.proboards.com/thread/5317/treble-bleed-circuit - just to summarize the findings, I think they come to the conclusion that sensible values are 150K/0.001u for 500K pots and 120K/0.001u with 250K pots, although either would work fairly well.
If you can find one, try 680pF and 220K - that's my preferred combination, in parallel.
http://www.gear4music.com/Guitar-and-Bass/Emerson-Custom-Treble-Bleed-Circuit-Volume-Mod/1LWZ
Wow again, imported from the States.
I must be missing something??
I bought about 20 different cap values and types from Maplins (by any measure the most expensive option) for about 3 quid total.
Resistors are cheaper if anything.
