I certainly wouldn't like to test it again though, and I don't understand why people would have this conversation. As though the only reason not to speed is because you might get caught.
Nor is the idea that "reflective" number plates will stop the number being recognised. They're just illegal as well.
As such, the only sensible advice is to not exceed the speed limit on your own speedo, and hope that it's not wildly inaccurate. You can't know how accurate the recording equipment is. So forget playing games.
Just because you're paranoid, don't mean they're not after youI believe that, legally, your speedometer is allowed to read over but not under. Therefore an inaccurate speedo shouldn't be an excuse.
The guidelines apparently don't really apply any more, but it is likely they are the source of a lot of these things. They show a usual guideline of enforcement being appropriate once a speed of +10% + 2mph is reached, but it is just a guideline. Also the equipment used is typically calibrated to +/- 2mph, but again this is generally, some of the kit is far more accurate.
The cameras are almost all set to this guideline, but if you drive past a school and leaving time at 34mph and get a ticket, don't bitch and moan, that is the definition of proportional enforcement.
Best way to avoid a ticket, don't speed If you stick to a maximum of speed limit + 10% indicated, then a combination of the guidelines and your speedo's inherent tendency to over-read a bit make it extremely unlikely you will get a ticket.
Also use your heads. You will probably not get pulled for doing 80mph on an empty motorway, but if you weave in and out of traffic at 75mph on a busy one, you probably will.
So if you stick to the cars reading you are always (?) likely to be within the law. I was told by two police officers (both former traffic cops) that the rules they applied were 5%+2 (not 10%). because that was reasonable but they had discretion both ways. Fixed cameras are not always loaded with film, but why take the risk.
You can get some calibration of your cars speed when driving through a village with one of those boards that tells you your speed via radar. Holding speed and letting you sat nav compare is interesting too.
Finally I'll pass on some wise words my son reitterated last year when learning to drive. The speed limit is a maximum limit not a target!
Drive safely everyone and leave enough time for your journey, there are enough cockends on the road, don't be one too.
SPECS, the average speed cameras, usually aren't on at night. Not always, but usually.
The bridge cameras on the M1 round Nottingham don't work, and that's why they have installed the yellow roadside ones on the bridge risers.
the 10% plus 2 mph is a definite myth.
If you are doing over 86 mph on the M40 in Thames Valley police area, you will get no option to do speed awareness, straight fine and points.
When will cameras be able to nobble people for texting and driving? Some berk was doing that the other day, in the middle lane doing about 80. Ludicrous.
I've always said this. However when my daughter learned to drive a couple of years ago they do seem to be told that they need to drive "up to the limit" to prove they are confident enough. She was too keen to put her foot down because of this, in my view.
