Where the looper goes depends on what you want to loop.
Overdrive > delay > looper > reverb.
> pitch changing (e.g. octave, pitchshifter, Whammy)
> gain/dirt and tone (e.g. overdrive, distortion, fuzz, and EQ)
> modulation (e.g. chorus)
> delay
> reverb
so, in your case
overdrive > delay > reverb
Re: looper
where you put the looper depends entirely on how you want to use it; i.e. which effects you want to have on your looped parts.
Possibly, last in chain, or last in chain before reverb, may suit you best.
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
i don't see what analogue v's digital has got to do with it, surely it's about the sequence of type of effect that matters.
"[the sequence of] delay and Reverb shouldn’t matter because, if the algorithms are correct, the result should be the same"
- eh? i don't get that either.
Analogue vs Digital doesn't matter for effects order. Effects type is what matters.
As for the latter, Reverb into Delay is never going to sound the same as Delay into Reverb - - - that's not how sound works.
Other delays / Echo pedals are before the reverb which sits much better in my opinion.
Whether it's going to work so well with a looper, I'm not sure - there's always a risk of making a big muddy mess if you layer too many similar thick sounds on top of each other.
Or you may like that .
