So I am thinking about buying my first pedal, no reason really. But what one?
I have a Vox Cambridge 30, it has reverb, tremolo, mid range boost , gain boost, and a clean channel.
http://voxshowroom.com/uk/amp/c30_hood.htmlhttp://www.voxshowroom.com/korean/amp/nu_cambridge.htmlI play stuff like Skynyrd , blues, that kind of stuff.
So, would a distortion pedal be a waste of money? The amp does do distortion Ok to my ears, reverb? Like the Boss FRV-1? My amp does do reverb and its a spring reverb but I have nothing to compare it to, would I see little gain in either of these?
Or should I just go for something fun like a Wah Wah?
I have often heard people asking if an amp can take pedals well? Are there amps that cant? I don't understand this.
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
Wah and fuzz are obvious ‘ it’s on’ pedals and used a fair bit in blues or blues rock. An octave pedal is good for making riffs sound thicker and a bit synthy , Warren Haynes uses his old Boss OC2 a lot in blues rock.
https://youtu.be/LztOqQoaH5I
Dont get the waza version of the SD1. that's unnecessarily expensive for you.
Octave seems an odd choice for a first pedal, imo.
If you're after an affordable dirt pedal - whether overdrive, distortion or fuzz - I probably have something if you're interested.
That way you can try out a bunch of sounds and if you.find them.useful splash on some dedicated stomp boxes if you think they sound better.
Is the pre-amp of the Vox Cambridge (when on Channel 2) entirely tube or partially tube?
I think I nearly bought a Vox Cambridge back in about 2000. I can't quite recall; it was certainly a Vox. I recall it had a chunky 'Celestion' logo on the grill cloth.
You have tremolo and reverb how about delay/echo add some different ambience, experiment with slap-back, longer echoes. Make weird noises.
This.
Those Zoom pedals are cheap and seem to produce decent sounds.
Then you can decide which pedals you want to explore further.
It depends what your budget is but if I were starting again I would get an Earthquaker Devices Afterneath, that is a sound your amp defiantly won't be able to do on it's own - https://www.earthquakerdevices.com/afterneath/
Reverb, tremolo and drive covered by the amp, so I would go for a delay.
Something like a Boss SD-1 may give you a nicer/better overdrive sound. Buy used for £25-30, and if you don't like it, sell it on for near enough no loss
Or a half-decent multi-FX, you can pick up second hand ones very cheaply compared to what they originally sold for.
or a Line6 M5 would give you a whole slew of options of delay, modulation and various others. The effect quality ranges from pretty good for the delays to so-so for some of the drives, but if you found there was one effect you particularly liked then you could look into getting a dedicated pedal of that type further down the line.
I reckon it would keep you going on the delays, choruses and phasers for a while though.
Top panel has a jack for a foot switch, this is the optional foot switch and controls channel switching and tremolo on/off , then there is the back panel that has another jack for a foot switch, this is the EXT. foot switch that controls reverb and gain boost, I have no idea how any of this would work?
Perhaps my first pedal should be a pedal to switch the amp?
It's slightly annoying that channel and boost are on separate switches, likewise tremolo and reverb - although in theory you could have a single four-button switch with two cables made, then you could arrange the buttons in any order. (Likely to be fairly expensive though.)
