WTB: Mains-Powered External Drive or High Capacity USB Memory Stick
As title says - my hifi takes a USB input but isn’t able to power a usb-powered external drive, presumably the current available is too low. Memory stick seems to work fine but I’ve only got a 16gb one and around 500gb of music! I presume that mains powered usb drives are old and generally unwanted so happy to find a use for an old unused one!
Powered USB would need to be at least 500gb, memory stick would be fine as either 256 or 512gb.
If i I can’t get one will likely pick up a 500gb stick in the new year :). Thanks all!
  • GagarynGagaryn Frets: 1553
    Unlikely to find a stick with enough capacity. I know eBay is flooded with cards claiming 512 GB and even 1 or 2TB but it is a scam. 256GB sticks are available though - stick with companies like Sandisk and will work fine.
    Yeah I’m certainly going to stick to a known ‘brand’ - I believe Sandisk do a 500gb one but it’s well over £100 and the performance specs on it (however much they matter) aren’t great.
