Dash Cam; front and rear - your thoughts ??
HI all,
Due to being involved in the car accident recently (non-fault), and due to covering quite a lot miles as business travel etc. started to think about dash cam.
I need something which is:
- not too expensive but don't want any cheap cr*p;
- is good at night;
- have fairly wide angle;
- constant recording (overlapping)
- small enough to hide behind the mirror;
I need front and rear, so maybe some packages ??
What do you recommend guys ?
Any good deals out there as its Black Friday (dont get it personally but maybe there are some good offers)
Cheers,
Chris
  • gjonesygjonesy Frets: 145
    maybe check with your insurer, you may get a discount on your premium if you use one that they approve
  • GrunfeldGrunfeld Frets: 4028
    edited November 2017
    - is good at night;
    - small enough to hide behind the mirror;...
    I've been using a Transcend.  (Personally, I've got the 200 -- and £80 now is cheaper than what I paid).
    The image quality is stunning and it ticks all the boxes you've mentioned.  Day/ night.
    It won't fit behind your mirror but I've used a suction mount from Day 1 -- basically the time it takes to stick it to your screen is less than 5 seconds; similar to take it off and hide it in the glove box.*
    This dash cam has already saved my arse once.  Worth its cost for that alone.  Not the cheapest but it works day in day out.
    PS I use a 32Gb card which gives you about 5 hours before overlapping.
    Hope that helps.
    And if I wanted a rear view one I'd just get another one of these.  They're independent so the data just gets stored on the card.
    *cos no one would ever look there!
  • KiniooKinioo Frets: 19
    Grunfeld said:
    - is good at night;
    Hope that helps.
    Thanks Grunfeld I will look into it - 80quid not bad.
  • skunkwerxskunkwerx Frets: 6838
    I’ve got a nextbase, 320g.. I think.
    It loops, has gps logging the journey, not that i ever use it, full hd, timestamps and everything.
    Its good and has served me well.. but the inbuilt battery is kak. I left it attached a few days in the summer and that was enough to kill it dead. It still worked, as I have it hardwired in, but when I shut the ignition off, it would just die insantly, thus not saving the final 3 minute segment of video.. which is most likely to be the only part you’d want!
    Halfords replaced it easy enough, but a year later I’m seeing signs that its internal battery is going again.. so maybe they arent the best..
  • 57Deluxe57Deluxe Frets: 7329
    On London Live News lasT WEEK THEY HAD A REPORT THAT IS A MASSIVE INCREASE IN CAR BREAK INS AND THAT THE POILICE SAY 90% are unsolvable. They will only investigate too if you have any cctv evidence from dash cams or other.
    So got me thinking: Dash Cam theft due to soar in coming months...!
    <Vintage BOSS Upgrades>
  • cj73cj73 Frets: 1003
    ^aye, that’ll be a sare fecht
    This is why I have a dashcam dashcam.
