The Mesa Dual Rectifier is like that - it doesn't have anywhere near as much clean headroom as a Fender Twin because it has a lot more gain early in the preamp, whereas the Twin has very little... so the Twin will stay clean all the way up to where the power valves distort, but the Mesa will overdrive first even though it's louder.
If I wanted an amp that overdrove 'early' I'd buy a brand known for such - and one that did so well. Fender amps are all about the cleans (OK, back it up Tweed people... I'll get to you) and IMHO, its what they do best. The HRD overdrive channel on the Mk3 can get you through a gig if you forgot your pedal board but you wouldn't want to use it solely.
Tweed amps, I accept are the exception - and there are some superb amps out there that use Fender's early circuits for their drive capabilities. However, if you want a Tweed Fender drive sound, you don't tend to be the sort of person who's going to buy a HRD - and visa versa. So its a bizzare thing to do.
FWIW - I tried lower gain valves in my HRD and it killed the warmth and sparkle. Yes it stayed clean but it took on the characteristics of a bad transistor amp. Perhaps I chose the wrong ones but I never found that volume was a problem with mine, even with the standard valve set.
The HRD does a *great* Tweed overdrive sound. I A/B'd one with a boutique 5E3 copy a while back, and you could get them to sound pretty close to identical. I will be fair and admit it was one of those limited edition tweed MkIIs with a Jensen speaker, but I don't think the tweed is necessary .
I really have no idea why the Drive channel is so underrated/disliked, even on the standard version - to me, it's one of the best features of the amp. It doesn't sound like a Marshall, no... it's not meant to. It's meant to sound like an overdriven Fender, and it does that very well. I know someone who recorded a couple of albums with one, and it sounds great.
Seriously, I've gigged my HRD in many scenarios - and no, I don't want it to sound like a Marshall either (I'd own a Marshall if I did). Its a nasty overdrive that flubs, it doesn't sit well in a band mix and if you want it to cut through its fizzy and harsh. Overdriven Fenders can be exactly that too but they can also be tamed - this channel can't. PLUS it gets lost in most band mixes, does NOT have the depth of sound at volume and just sounds... fucking horrible.
Perhaps I should say that I'm not a fan of the farty/flubby/Neil Young having a wig-out 'tweed' sound others seem to revel in. Each to their own and all that but it just sounds like the amp is busted or just about to. If thats the 'tweed' sound that floats your boat, then perhaps the dirty channel of a HRD is right up your street...
However, the clean channel with a good overdrive pedal (Okko Diablo for example) is a great sound that cuts and retains a non-Marshall flavour. Its also how the *VAST MAJORITY* of owners use them!
https://store.cdbaby.com/cd/splendid
Listen to 'Shining On You' in particular, that's a *great* light-overdrive sound. Or 'Love Rains Down' from the other album...
https://store.cdbaby.com/cd/splendid2
I saw them live several times and the amp always sounded fine in the band mix too.
Yes, it does that as well . In fact, I got the very best low-volume Neil Young sound I've ever heard out of one, with a Danelectro. Set very differently though, with the bass up full which you would never normally do.
I know, and it still baffles me. A lot don't seem to want to even *try* to use it...
You may be surprised that I don't own one, in fact. One of the main reasons for that is that I don't like amps with top-mounted controls, or I may do. And I'm still tempted sometimes.
As someone who gigged with an HRD III for years, I couldn't agree more. But each to their own
contactemea@fender.com
I've heard cleaner 40w amps, I used one for a few gigs once and liked the way there was slight breakup at manageable volumes. When I say breakup, it was more a warming/blurring on the clean channel when getting to decent levels.
That said, this one had the old Fender Special design in it, I think they have a Celestion A type now which should be louder. And for more headroom you could always swap that for a Gold or G12H
I also like the gain channels, although out the gain / volume sweet spot they do sound pants.
I can't remember but I'll take a look in a minute, they where TAD higher spec 6L6, and 12AY7 in the preamp positions, again these where reasonably respected quality stuff. It made the little 1x12 blues amp a fantastic amp. I'm pretty sure I've posted about the magic blues deluxe amp that I found on this forum, but these valves really helped it.
My favourite set in either a Blues or Hotrod Deluxe is a 12AY7 in V1, 12AX7 in V2 and 12AT7 in V3. This opens up the tone of the clean channel while leaving the Drive channel sounding good .
I've found the biggest contributer to higher headroom and 'better' tone in fender amps is to get the highest spec power valves you can afford. I put a set of Svetlana Winged C 6L6s in my Custom Vibrolux Reverb and it made a hell of a difference. Still not the most headroom for a 35W amp, but great tone.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Personally I don’t think there’s anything wrong with the MkII, I’ve never thought the MkIII sounded quite as good.
I think I tried that trick with my DSL50 too. "Pre-RoHS leaded solder, the good stuff!"
does this make the deville Iv more tempting?
