hi people. Need some advice
just bought a Single S-Grille pickup Harmony Rocket. Pickup sounds great . However the tone control ( According to web info itwill have a 0.02 cap on a 250k pot ) when turned down removes almost all the sound. I understand this can sometimes be a sign of a broken pickup, but it sounds great when tone pot is open or nearly open.
Might it be a failed cap?
i know i could just try a replacement, but its a fiddly job thro the f holes so so id rather ask a few experts ( you lot) first
if so any advice on sources of replacements?
Thanks
chris
Do you have a multimeter? You can check the pickup from outside the guitar if you plug a cable in, turn the controls up full and measure the resistance at the other end. If you get a normal pickup DC reading (typically 5-10Kohms) then the pickup is fine, if you get the volume pot value then it isn't.
Would the pickup sound so good if it was broke ?
it was the ‘plug in a lead and try it’ that helped me. Because im a chump it never occured to me to do that
thanks guys much relief . Even tho i like the sound i couldnt have settled if it had been faulty.
Sources of replacement caps ?
views on idea of adding a further ( bridge) goldfoil - sacriledge or good idea . Ill see how it performs at rehearsal tonight.
Lovely thing tho
Thanks again
AxesRUs sell orange drops if that’s your thing.
