I'm getting a really weird fault with my wireless kit. It's essentially sounding like a loose connection on that you play a note but the signal is intermittent and sounds slightly distorted. I've tried new batteries, replaced both cables and all six channels. Occasionally it's fine on one channel for a few minutes.
The signal lights always come on green and the play light chimes on when you strum.
Are these things repairable? If so, home job or recommend me someone?
Thanks
Its the built in "Autocorrect" feature trying to improve your playing... Its trying to quantise the output - just select the "free form jazz" setting and its will let the original signal go through unaffected.
Ebay mark7777_1
Just because you're paranoid, don't mean they're not after youI play guitar and take photos of stuff. I also like beans on toast.
What can happen is that the contacts get forced/bent because a slightly too big battery has been fitted and this means that the contact isn't quite so good.
A test is to play a sustained chord and either wiggle the door or move the belt pack around in your hands, to that gravity affects the battery. If thats the case, try bending the contacts inside the case (a small loop of string/cable can assist).
@impmann I've tried bending out the battery contacts as they seemed very flat. If it was this though I wouldn't expect the lights to stay on.
Just because you're paranoid, don't mean they're not after youIt may not be that - but it's worth a check. :-)
Just because you're paranoid, don't mean they're not after youBin it n replace it...you can pick up just the transmitters on eBay for less than the price of them both. I keep looking for a 2nd transmitter and have bid on a few but so far always been gazumped. Mines served me well through lots of gigs over the last 4yrs...still as good as new. Apart from putting a cable tie over the battery door to ensure it stays closed I've never had an issue. I do 2 gigs then recharge my 2 AA 's...and always carry a spare set. I'm a huge fan of the G30 and wouldn't be without it or one like it now.
Just because you're paranoid, don't mean they're not after youwell send me your transmitter and I will test it on mine...and post it back to you. You can pay the postage both ways though...in the name of science n all that!
There is no mini XLRs on the G30.....its standard jack to jack!
Just because you're paranoid, don't mean they're not after youI’m a bit miffed that I have to buy yet another wireless to replace mine.
