5e3 noisy when channels are jumpered
interstellarinterstellar Frets: 486
edited May 2018 in Amps
got my first deluxe today, sounds great but when i "jump" channels there is quite a bit of noise  any thoughts?
cheers
  • 57Deluxe57Deluxe Frets: 7339
    edited May 2018
    yes, thoroughly clean the amp's jack sockets inside and the plugs on the jumper leads. Also, ensure the cables are top quality and not have damaged screening.
    This is a common issue of the 5e3 design if the amp has stood around unused for a while - even indoor environment.
    <Vintage BOSS Upgrades>
  • TheMarlinTheMarlin Frets: 7880
    Use a high quality jumper cable, as short a cable as possible.
  • martinwmartinw Frets: 2149
    Try not jumpering  just turn up the other channel volume.....might be enough.
  • MtBMtB Frets: 922
    You do know that the volumes on the two channels are interactive? And that the tone control past about 6 on the dial has less and less impact until at 10 it has no effect on either channel?
    This may be if interest: https://robrobinette.com/How_Fender_Input_Jacks_Work.htm
