I’ve been trying out a lot of different amps lately.
My findings are -
jcm800 2204 is much more powerful than any other 50 watt amp I’ve tried. I’ve had it up against a jcm900 50 watt and a jubilee 50 watt and it’s louder than both of them . The 800 on 2 or 3 gives similar volume to the others on 5 or 6.
So so I want something less powerful than the 2204 . But as not all amps are created equal I don’t know what I should be looking at.
mesa stiletto 50 watt ?? Or is this gonna be too powerful too ? Although some other 50 / 100 watt amps I’ve tried don’t seem to be as unruly as the 2204 .
Orange 15 or 30 watt ??
Jet city 20 watt ??
The Mesa will be much more controllable - not quite as loud at full tilt, easier to adjust with the multiple volumes, and with less of a change in tone relative to volume probably.
As with all of this you're going to need to try it though - we don't know exactly how loud your band plays. Amp power outputs are only a rough guide to final volume, there are so many factors involved that it's impossible to generalise unless you're talking about the difference between say 15 and 50W - and even then you can get a surprise if you compare something like a 15W Matchless Lightning to a "60W" Marshall TSL...
Remember speaker efficiency makes at least as much difference too, you can't really compare the amps unless you're using the same speakers.
Subjective loudness also depends upon the "voicing" in the amp. This is the baseline frequency response. Amps rarely have a flat response with the tone pots at 12 o'clock like a hi fi amp or mixer (find Duncan amps Tone Stack Calculator) so, as IC says, it is almost impossible to quantify loudness difference (you can of course MEASURE the power output but even that is a movable feast!) .
Do not, ever go by VC or gain pot positions. That is entirely in the gift of the designer and means Jack. A change of pot 'law' (common mod?) or even ONE extra resistor and the indications go all over the shop but obviously the max POWER output has not change one milliwatt!
Speakers? Yeah, ******G SPEAKERS!
Dave.
2nd will be cabinet design. Open back, closed back etc etc have an effect on how speaker operates if freqs get cancelled out and so on.
the 25w rating can be taken it different THD figures so one may not be useable clean to same volume.
lastly some amps power transformers may be less capable so amp can't keep a constant 25w maybe just peaks
Output transformer efficiency as well.
So answer is can be huge diff in volume between one amp and another rated at 25w biggest aspect will be dB/watt of driver. Bit add all together and can be huge. Eg a driver twice as loud sensitivity wise would make a 25w amp perform at same volume as a 100w amp (4x the power in watts to double volume)
Bear in mind that a 15W amp through a 4x12" with V30s will be louder and cut through a mix much better than a 50W 1x12" with a G12T-75 - even assuming all other factors are very similar - and you may get some idea of the problem. And yes, a Matchless Lightning really is louder than a Marshall TSL60.
Expecting all 20w amps to be the same volume is like expecting all 1.5L cars to have the same top speed.
The wattage is usually the maximum amount of power at a cleanish setting, so the more Overdrive the amp provides the louder it will be. You also have to take into account the speakers efficiency, how many decibels it produces per watt, and this will be different at different frequencies.
You have to also consider the difference between actual and perceived volume. Humans hear different at different volumes even if the dB level is the same.
How loud is a 50W amp?
How fast is a 2000cc car?
The Watt is a unit of power, not a unit of volume, just like
the cubic centrimetre is a unit of volume, not a unit of power.
* twisted to be even more beautiful by the sneaky pun on volume.
This is my only concern
