Hi all,
I'm new to the forum and new to acoustic guitar.I've played classical guitar for a few years and reached a lower intermediate level.I've decided I'd like to move to acoustic guitar and use a fingerpicking style. I don't have any set style of music in mind although I'd like to learn the alternating bass, thumb picking technique like travis, Atkins etc..I have a little Martin LX1E which I tend to noodle on.I've decided to go for a decent acoustic guitar.I have ruled out dreadnoughts and parlour guitars but I'm a bit mystified over the OM,000,00 and 0 (is that classed as a parlour guitar?).I know various makers make claims about their various models but before I try anything out could anyone out there tell me what to be aware of or expect in the different models.I won't be doing a lot of strumming hence ruling out dreadnoughts.I won't be playing publicly,I'm looking for comfort, ease of play, volume, sustain, clarity and note separation.I'm assuming each model has different characteristics so I'd value your observations on what those are.Sorry if the question is a bit woolly but any opinions would be welcome.
Don't forget maple as a body wood either - it has a reputation for being very bright, but really it isn't, it's more like a tighter, less boomy rosewood (to me) and is very overlooked for some reason. Other woods like walnut are also sometimes used.
For acoustic playing I use an Atkin OM which is just about ideal.
I wondered why OMs and 000’s differed but didn’t realise different scale lengths produced different sounds.You both also mention neck width.I have large hands and would be looking to go for the 1 3/4" nut width.Anything after a classical guitar neck seems to disappear in my mitts.I appreciate the difference in technique but I'm quite comfortable wrapping my thumb around the neck.Nevertheless ,a point I wouldn't have considered otherwise.With respect to tone woods I do prefer rosewood.In the video above I prefer it over mahogany and its something I'm familiar with. I'm not sure I would like maple.I've come across it on flamenco guitars, to me it is too stark and snappy.I'm also someone who values an instruments aesthetics and for me rosewood also wins out. (my avatar pic is a guitar I made myself using BR).Jim,you mention Atkin guitars, they are one of two makes I'm interested in ,the other being Martin. Atkin guitars seem to attract great reviews.I have eyed the 00 size which on my understanding is more classical guitar sized.I'm selling a couple of guitars to fund this change in direction after which there's nothing else for it but to try them out.I'm sure something will jump out at me.Thank you for your replies ,I appreciate it.
I'm not familiar with Atkin, but the Martin OM-21 will be everything you want - it's a rosewood body with very plain trim. I had one, which I loved the sound of, but I couldn't get on with the neck width and string spacing as I have small hands and taught myself to play 'folk' style with my thumb around the neck (yes I know ). I sold it to a friend who is a proper classical guitarist and it's absolutely perfect for her.
IMO, if you play fingerstyle then a 12 fret 00 (or even 12 fret 000) is very good match for a guitarist who plays nylon strings mainly as they are likely to have a wide nut be it 1 13/16" or 1 7/8". A slight bit of caution for 12 fret 000's as they might have a bit more bass and I find they can often be a bit too much for fingerpicking.
Aside from the nut width, keep an eye out for string spacing at the saddle. For classical guitars they have a fairly wide string spacing at the saddle around 60mm or so, whilst a lot of acoustics will have ones around the 54mm or 55mm wide and it does make a difference.
Btw, a true 'parlour' guitar is one smaller than an 0, which would have 12" lower bout but a lot of people seem to use the term to describe any guitar smaller than OM it seems.
Thanks for your reply,you’ve shed even more light on this subject. I’ll certainly take account of the string spacing at the saddle.Typically a classical guitar is 650mm scale and a 52 mm nut. Everything else is about tonewoods ,bracing and construction.There are so many more variables in the acoustic guitar field it seems to me. Thanks for the steer on the 000 12 fret. I don’t want an overpowering bass response, I’m after clarity and balance. I’m definitely seeing things more clearly now, this is just the advice I set out for.Thanks.
I didn't think I could afford a Lowden but tbh I'm not over keen on their appearance.The thing that prompted my original post was the fact I was looking at Martins and Atkin guitars.It seems that Atkin guitars are based on a similar sizing code so it's fairly easy to make a direct comparison.I have a budget of circa £2.5k but that depends on a couple of sales I need to make.You're not the first to mention a Martin OM and it's definitely on my try list.Many thanks.
I'm an atkins/Emmanuel thumbpicker and am selling a Taylor 714CE if you fancy a crack at that. The neck is 1/4 and I can attest to how good it is for that style...I learned Cannonball Rag on it after all lol. Its RW back and sides, onboard electronics, the hole deal.
Thanks but I'm looking for a smaller guitar than grand auditorium.I don't want electrics or the cutaway either.I think once you start with an idea in your head about what you want, it's pretty hard to change.
The Atkins OM models are lovely. I found the Martin OMs to sound a bit flat in comparison. I bought a Brook Taw (Spruce top, Bubinga back/sides) and love it.
Both the Brook and the Atkins benefit from a light touch.
Since I started the thread, I've spoken to Alister Atkin. We talked about my previous style and what I was looking for.He thinks I'd be best suited to the 00037 model .It is the same shape as the OM but has a wider nut.At the moment I can't find one locally to try out, plus I'm raising the funds through a couple of sales.That said,Atkin guitars do have a very good reputation and you're another one praising them.I'm not over familiar with Brook guitars but shall now have a look.Thanks for reply and good to hear from a classical player.
Another guitar maker, I'd recommend looking out who makes 'traditional' sounding acoustics in the Martin style of things are Furch who have new models new in your price range. If you are happy to look for a second hand guitar, then you might be to find a Collings. A new Brook would be bang on your budget and if you order directly from them you have the guitar built to your exact specifications.
I seem to spend most of my time playing nylon strings not classical, but flamenco and my main guitar has a neck of 53mm wide at the nut, 650mm scale and about 22mm thick at the first fret. It used to take a bit of adjustment to play other guitars of mine with smaller necks but the more I practice the easier I am finding it to switch between other guitars which have thinner necks, narrower nuts and so on. One thing which is a must for my non nylon string guitars are necks with a bit more meat to the profile as I have found my technique for my fretting hand is for the thumb to sit on the centre of the back of the neck as I do when I play flamenco guitars and with thinner necks my hands seem to cramp up.
You're right, the Atkin OM model has a smaller nut width. The more I contemplate my purchase the more I err towards British made.If I'm going for a decent guitar I'm going to veer away from second hand.Also,I'm going to avoid mass produced factory stuff.I've looked at Furch but the build process leaves me cold.I'm sure they are very good instruments but I'd prefer something produced by a small team or individual luthier.Having looked at your post and that of BigDipper (a former classical player like myself)I am now taking a SERIOUS look at Brook guitars which tick a number of boxes for me.Not least the ability to specify certain things without it becoming a "custom build".they're not going to break the bank either.I've commissioned classical guitars in the past and there's nothing like knowing your instrument is being made on an artisans workbench as opposed to flying off a conveyor belt.(If you know what I mean).Thanks for another solid bit of advice.
I bought my Taw from Project Music in Exeter. It was an unexpected purchase, as I was just visiting for research purposes (having decided I liked an Atkins OM and a Huss & Dalton OM I'd played elsewhere). They had several to try out - including two Taws made with different woods - and I couldn't stop playing the one I eventually bought. No regrets. I'm sure I would have been happy with the other two I liked, as well.
I'm too impatient to wait for a bespoke guitar...
