Q418c WezV Violin
I am mainly in to organise this challenge, so won't be an official entry in the vote for the winner
I decided on a Violin kit.   The cheapest one available from china ;)
This is the kit i will be using
https://www.ebay.co.uk/itm/DIY-4-4-Size-Violin-Kit-Natural-Solid-Maple-Full-Set-Violin-Parts-White/282933766542
The plan is to assemble it into a working Violin.  I want to see if i can take a basic solid wood kit and do a bit of tap tuning on it to develop the sound.
I have not yet decided whether to do a traditional finish, or something more out there
  • enjoenjo Frets: 278
    Cool! I can't see a mention of a sound post - might want to check that out when it arrives & also make sure there is some kind of bass bar.
    & Don't forget the bow!
  • SporkySporky Frets: 28295
    I've got a spare cello bow if'n you want to borrow it, Wez.
  • WezVWezV Frets: 16682
    Ay, that would be awesome.   I have rosin for things like stopping bridges sliding about... never got around to buying a bow even though i always wanted one for guitar.  Are cello and violin bows the same/close enough.  I have no clue
    I know a bit about the construction side, so i know what a sound post is and what its supposed to do.  Never fit one before though so that will be fun. Is it considered wise to screw them in place, seems like it would stop it moving again ;)
    I might actually take the top off when it gets here to tune it a bit
    About 10 grams difference and some shape differences. There are cellists who use double bass bows so to some extent you can mix.
    Well that kit never arrived, refund was issued and a new one has been ordered
  • DannyPDannyP Frets: 1677
    Bummer. I'm now picturing a corrupt postie trying to glue a violin together...
  • RolandRoland Frets: 8711
    More likely a seller who didn’t post it
    back in the game, the second kit turned up on time
    the good news is its all solid woods and there is little to stop it being a good instrument once put together
    There are no instructions, but i didn't really expect any.  i think the most challenging bit will be fitting a sound post
  • I want one just so I can put it on display and pretend to be posh.
    £35!?!?!?!
    I'm not clued up on the price of wood but that seems really cheap so gives me concerns about the ethics of the supply chain, and the labour that is producing it.
  • JayGeeJayGee Frets: 1260
    So are you going for fanned frets on this one then? :-)
    Distressed Seafoam Green, yeah?
    Flip-flop!
  • Could this kit be reasonably modded to make a ukulele or mandolin?
    I bet you all though i wasn't going to finish this didn't you!!
    Well i have.... today.   its not perfect, but it does sound surprisingly good
    a little while back i stained it, to add some underlying dirt to later finish steps... looks good on the back
    the fretboard was just stuck on with 2 spots of glue... which is exactly what i was hoping for as the fingerboard is normally removed for finishing
    neck tenon got cut
    and glued in
    i decided to do a few coats of nitro for the finish, but got a bit caught out spraying the complex shape so its not perfect...i did red and a light black tint over  it to get to this
    i gae that a good rub back with wire wool and wax, and darkened the other wooden bits
    then i reglued the board and assembled it
  • normula1normula1 Frets: 640
    Looks good.
    Out of interest, do violins not have stain on the neck or no finish at all? I'd always assumed that the finish had simply worn away with use.
    they are usually just oiled.  i have stuck to it on this one
