That's kind of like asking "is there any benefit in putting cheap petrol into a Ferrari?" Well, yeah, cos it's still going to go faster than a Nissan Micra with the same cheap petrol in it...
Benefit compared to what?
Is it a good valve amp, or a crap one?
What's the signal? If you mean (for example) SPDIF, then probably not. If you mean the analogue output of a digital processor then there might be.
Having something digital in the signal chain doesn't result in a massive, irreparable loss of mojo because mojo is not part of the signal chain.
OK. If a valve amp is chosen for its analoguey goodness, does its goodness get reduced by firing a digitally processed analogue signal through it? Does it not amplify all the digitalness?
If the digital processing produced the results you are after wouldn't it be better to amplify that with the least colouring amp available? And then you don't have to put up with all the drawbacks of valve amps?
Digital does not sound worse than analogue. Anyone who says it does is trying to sell you something you don't need. Some digital things sound better or worse for some applications than some analogue things.
If what you like is something digital into something with valves then grand. If you like a valve preamp into a Line 6 Spider then more power to you.
But normally, yes drink the stuff........ along with nice bit of cheese.
This is why plastic pedals like the Ibanez TS-5 don't have mojo, because the plastic casing breaks the mojo path despite the circuit inside being identical to the metal-cased TS-9. There must also be no plastic-bodied PCB-mounted jacks because they break the mojo path and stop it getting to the casing.
Shakeproof washers are also thought to affect the mojo path, which is why so many boutique pedals don't have them.
Traditional wisdom says the following:
1 - The Rocktron will be nowhere near as loud as the R&R
2 - The Rocktron will sound nowhere near as good/warm/authentic as the R&R
Tradition wisdom is...wrong on both counts. At least, for all practical uses, the Rocktron has more than enough headroom to play over our band (and to be heard clearly when playing solos). In terms of "sound nowhere near as good"...nah, it's just not there to my ears. There's no "digitalness" to be heard with either amp, and while there's a bit more top end with the Rocktron, that's about the only difference I can discern.
Which is the first commercially-produced solid-state amp...
I think a good power amp is far more important than whether it's got glass bottles in it, to be honest.
As a case in point, I'm currently looking at the Camplifier Guitar Brick 180 - if it does what it says on the tin, it's going to solve all my problems in one go. Good amp, plenty of headroom into 8 ohms (unlike the SD Powerstage 170), small enough to fit in the rucksack I use for the Helix and only weighs 1kg.
But the 2:90 I have with deep engaged can do things I can’t get my GT1000FX to do.
