This has happened before- probably an autofill-on-mobile device sort of thing.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
If it's got a guard you can add a swimming pool or smuggle routes, but don't expect to lose more than 1/2lb max
Carving the contours a bit more can also shave a bit.
You don't need to bind if you do retop it, but it does look best if it's going to be natural. If it's a solid or burst finish I would not bind, and I don't think it would suit the guitar.
I have chambered and retopped a few guitars. It is the most effective way to reduce weight.... But not easy and not cheap
Instagram
The reason for the thin cap is to weight relieve a mahogany lp body i made years ago, i need at least 3/4 lb off it
(formerly customkits)
I wouldn;t normally saw the top off, although have done it by hand once. That was enough.
I normally route the body thinner, chamber it, and make a new top
Instagram
I can't even saw the bottom of a Christmas tree straight
I've got one more cap to split which is by hand so not rushing, then I'll probably do a build thread
