Has anyone extended their wi-fi signal to say, a home office in a garage or somewhere over 100ft away from their superhub/router/access point?
My garage (due to be converted) is approx 50ft away from the back of my house. The VM superhub lives in my room by the window directly opposite, but I notice the wi-fi signal drops out once I step foot in the garage (now over 60ft in range.)
I know you can get these Powerline booster things to extend the range but I don't know how far it goes. One plugs into the superhub and one into the location where you want to extend to. VM being cheeky bastards want £3 per month "rental"!
The other option is to run an ethernet cable from the house to the garage and plug that into a booster but that's £100 installation and the monthly rental charge. I've seen other Powerline's on Amazon but not sure the range and if they'll work.
Its mainly for iPad's/Smartphones to be connected not planning on any PC's or laptops etc.
Otherwise you will need to try a Powerline adapter- it depends on more than just distance as to whether it will work.
Another solution is a 4G network device.
My iPad isn't data enabled, if that's what a 4G network device is? Only my phone has data allowance.
It is this sort of thing:
https://shop.ee.co.uk/broadband/4g-home-broadband
1) physical cable connection
2) powerline
3) point-to-point wireless bridge
If you're at the "building works" stage then personally I would get at least two exterior grade shielded solid-core ethernet cables pulled along with the mains through the same ducting (hence the shielding, you shouldn't run data right next to mains in theory). Get them terminated properly at both ends on sockets (patch panel would be OTT) and then patch in appropriate devices at both ends to join it all up. However, if you do this, be aware that depending on the distance etc. you may need to use fibre, not copper, to avoid safety issues with different earth potentials at each end and stuff I don't really understand. At that level, you talk to a proper data cabling person, not just a sparky who thinks that "Category 6" is valid because it's printed on the sheath.
If the above sounds daunting, powerline is simple if everything runs back to the same consumer unit.
If you don't fancy power line, a point-to-point wireless bridge is OK as long as there is a good line of sight, particularly no trees/bushes. It will be dearer than powerline, though, by the time you've got appropriate bridging units and so on.
Powerline is my first option I want to try but til I know what the range is I can't be sure if it'll work. With the location of my superhub the only things obstructing signal is my window, and the garage wall. I've read you should move the extender thing in the middle of the two but the only position I can think of is in the downstairs kitchen socket directly opposite my garage.
The WiFi Extender powerline adapter can just duplicate the existing 5g / 2.4g network on the router so you don't even need to fart around changing networks you connect to. In fact, I'm currently in the cabin, and get the same speed down here as I do in the house (on both 2.4 / 5).
Oh, and they also have 3 ethernet ports so you can hardwire devices in if needed.
https://www.amazon.co.uk/gp/product/B01JIFYQZM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I tried various other options, all of which were not suitable - mainly as they kept crapping out.
Don't use an extender with Powerline. In fact, don't use an extender, they're crappy and halve your bandwidth
Get a Powerline device that has independent wifi at one end, and a wired connection at the other.
Plug the wired powerline adapter in near the hub, and run an ethernet cable from hub to powerline.
Plug the other powerline adapter into the garage, and set it up as a discrete SSID (it's still all on the same subnet, so it doesn't matter if it has a different name/password, the network addressing is all the same).
That way you get full coverage of wireless from two discrete sources in two discrete locations, and the powerline connection shoves the data between them.
https://www.amazon.co.uk/TL-WPA4220KIT-Powerline-Broadband-Configuration-UK/dp/B01LXOZ4EN/ref=sr_1_3?s=computers&ie=UTF8&qid=1540829145&sr=1-3&keywords=powerline+wifi+extender
They never say what the signal range is on them though.
https://www.amazon.co.uk/TL-WPA9610KIT-Powerline-Broadband-Configuration-UK/dp/B072QWSCQS/ref=sr_1_18?s=computers&ie=UTF8&qid=1540829145&sr=1-18&keywords=powerline+wifi+extender
That WiFi Extender does NOT piggyback on your existing wifi range; it uses the powerline to connect to the router, and it then uses it's own in-built wifi magic to create a seperate wifi area (but if you set the same SSID on the wifi of the extender, you won't see any difference).
It's using the powerline aspect to communicate to the router, NOT the wifi. the wifi is used from the adapter for devices to connect to.
Also, the thing about running a cable isn't so you necessarily plug your device in. It's so you extend the network to that location, then you can plug a wireless access point into it, and still use all your devices on wireless. The problem you're trying to solve with all of these things is extending the network not the wireless, from the house to the garage/other location. Wireless is just a mechanism for getting kit on the network.
It's easier with pictures
In the real world range will be greatly reduced by buildings, RF/electrical interference, the density of other wireless networks in the area (in central London devices that claim hundreds of metres can have an effective range of about 10m or less sometimes) - it's a minefield, and should be taken much like broadband speeds of "up to X".
