Yes it’s a 68 Custom Deluxe Reverb - the reissue ones, not an original.
it seems that for now if I want to play I’ll just have to unplug the power line whilst the amp is on.
Website || Feedback Thread || PayPal
btw - Im using the powerline extenders around house n need net access for work - but not experiencing your noise issues with valve amps - is the 68 DRRI particularly sensitive or is it a rogue / microphonic valve youve got in V1 etc ?
I found this - https://www.gearslutz.com/board/so-many-guitars-so-little-time/1067548-fender-68-custom-deluxe-reverb-common-problems-fixes-upgrades.html
also consider changing extenders - ?
https://www.techadvisor.co.uk/test-centre/network-wifi/best-powerline-adapters-for-2018-3490638/
or look at Mesh ( new to me )
https://www.techadvisor.co.uk/test-centre/network-wifi/best-mesh-wi-fi-network-systems-2018-3661110/
good luck btw
interesting that your power line isn’t causing you issues. Which ones do you have? I’ve only had them for two weeks or so so won’t be investing in mesh or changing them out any time soon. Thanks for your input
Tacima 6 Way Mains Conditioner https://www.amazon.co.uk/dp/B00UB0G4DQ/ref=cm_sw_r_cp_api_8KO5Bb0C46DXS
Seems to affect mine only on the gain channels - can the noise (or what is causing the noise) have any adverse affect on the amp?
You can check if it's this (or how much of it is) simply by turning the reverb off.
If it's not that, a simple power conditioner probably won't help much, since it won't fully isolate the amp from the mains.
Interestingly when certain effects are on its not a problem - like the Growler patch - but when running an amp model and using headphones with the Stomp its still picking up the powerline interfaces.
Very odd. I suppose nothing much I can do still?
I have similar problems (noise in amp, noise through Stomp) but its actually my guitar picking up noise from my PC.
In my case unplugging the USB cable that connects PC to Stomp makes a huge difference.
Its not consistent though - for example its not as bad if everything is in a plugboard. Yesterday I had the Stomp, Pedalboard and Amp plugged in to a plugboard and whilst the noise was still evident, it was much less noticeable than if they were plugged directly into the mains.
I'm wondering if theres a fancy plugboard I can get?
