As titled. Suggestions please! Am building one in the 2018Q4 challenge.
I like the idea of a Celestion Blue because I've somehow never had one, and the LazyJ crowd seem to agree it's a good fit for the basic circuit. But at 100db i'm wondering if there's anything better for home use (ie 96db or less!) that sounds similar, or even suits the circuit better.
Equally, I'm adding a variable voltage mod once I've got it working, so maybe I shouldn't worry to much about speaker sensitivity...?
Thoughts please, oh knowledgeable tweed people of t'fretboard
Tone-wise, how do they stack up? I'm really more keen on the Blackface sort of thing than the raspy thing that Tweeds & Voxes do, so hoping to get something that leans away from "rasp"
The Jensen P12R, P12Q, and P12N all sound great but do have that papery rasp which some aren't too keen on.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
So perhaps a bigger magnet ceramic for more blackface. Eminence CRex might be nice?
I have a Celestion G12H anniversary in my 5e3 and so far so good. I got that after coming accross some Greg V vids on youtube, it’s the speaker he goes for in this amp type. Personally I thought it was worth trying as it’s significantly cheaper than a blue.
Jensen Tornado - really. Very clear and even, not raspy - but not too smooth or dull either. I’ve only tried the 100W Classic so far, which is perfect in 60s-70s American-voiced amps. If you want lower sensitivity you might be better with the 80W or 65W one - there are good clips on the website.
but still loud
Cannabis Rex is nice if you play a tele or strat through it.......takes the icepick top away
The thing is, I've never played a 5e3, and I'm pretty sure my next-next amp will be something blackface-flavoured, so I'm not sure whether I should really lean in that direction, or embrace this thing for what it is, and go for "maximum tweed"
If you want it to sound more like a Blackface, avoid anything too low-powered or middy, as you don't want cone distortion or more midrange than the amp already has.
If you want a Weber 12a125a, the one I have is up for sale.
The trade off is that tweed overdrive will be a lot louder ( but I see you’re planning to build in attenuation, so that would be ok)
Also, a good eq pedal in front can also give you some BF style scoop ...
( there’s a good TPS on eq pedals)
I do have a great blackface-y pedal (the virtually unknown Anarchy Audio Gold Class) and I'm not even that keen on the Tweed breakup thing, much more the chimy just-past-clean thing, so I'm edging back to a Celestion Blue as a starting point then maybe try other things once I have a benchmark, and only if I feel the need to.
I tried my Tweed Deluxe with my Princeton the other day. I was amazed the difference in tone.
I think trying to get a tweed to sound blackface will be almost impossible, whatever speaker is in there. Perhaps with no cone breakup and a speaker without too much extra mids, it would be slightly in the blackface direction, but that’s only 10% of the journey.
I guess NFB and fixed bias mods would be a possibility, and with the right speaker it might start to sound less tweedy.
I think it’s probably easier to go the other way round, blackface in the direction of tweed with the right pedals.
I had a WGS G12Q in a deep-ish cab and it was lovely, but in a Blues Jr cab it sounded like an 8" speaker, no matter what amp I plugged into it.
I didn't like the Celestion blue or gold with them
I'd say just get a Jensen or an Eminence Legend 1258
I did have a Tayden Alnico that worked well, but it had a different sound to the Celestion Alnicos
I bought the 1258 after a chat with the owner of Victoria amps, who told me the breakup was much smoother on the 1258 than on Jensens (and that he now fitted 1258s as standard). He was right, the breakup was much nicer.
