Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
What would you recommend other than Danish oil? I am not sure if it went sticky because of the anti bac spray used to clean the worktop daily or if the oil didn't cure properly...
Meths and oooo gauge wire wool after sanding down then use the Osmo
Pretty sure you can get it pure, the stuff the missus uses often has perfume and moisturiser in it which you probs don’t want on your countertop.
The episode beforehand was how to strip the worktop using some new Bosch sander which was quite interesting too.
I would also add a recommendation for Osmo products.
However, I would caution the use of steel wool on an oak top - any steel wool fibres/dust that get left behind in pores or scratches will stain the oak (due to oak's tannins - google for vinegar/wire wool stain). Synthetic mesh scuff pads should do much the same (if fine enough), but no danger of staining.
Adam
Eastlea is a genuinely likeable lad. He’s enthusiastic, talented, and knows his onions - good to see the young’uns getting stuck in.
