Just about to try some different pickups in one of my guitars. With so much choice its difficult to know what to go for, and Im thinking that once you soldier the pickup cables thats it you can't return them to store, even though it would be a clean job. This could end up being an expensive journey! Is there any online dealer or actual shop that accepts returns of pickups that have been tried, or even accepts swops? Maybe I am simply dreaming here.
Failing that I will just have to wait for ones to come up on here or on eBay.
To give you an idea Im looking for a new HSH with the HB being 50mm spacing. I like the sound of the Suhr SSH+ and SSV set, and perhaps even the Suhr Aldrich in the bridge. Also, would like to try the Di Marzio Humbucker from Hell on the neck. I like the idea that it might sound somewhat like a single coil pickup on the neck.
Screw terminals would be a great idea to swap and change as has been previously mentioned.
Oh and I except swaps for pickups too.
That would definitely count as a used pickup at that point. It's a particular nuisance if it's a covered humbucker, since to change the cable properly you have to take the cover off.
We have the best pickup winders in the world here in the UK.
Genuinely, if you can’t get the sound you are after from one of these guys, you won’t get it from anywhere else.
I say that after 30 years of being down the rabbit hole of guitar pickup tinkering!
