I've found a few Fender amps where the reverb tank is the wrong way around and thus prone to picking up noise.
The reverb out from the tank should be on the right hand side looking into the back of the amp, ie away from the mains transformer.
The mains transformer sprays out electromagnetic interference which can be picked up by the tank.
Wiring the amp to 240 VAC rather than 230 VAC will also reduce noise emitted from the PT.
There are two connections at either end of the tank: input and output.
The output is quite high impedance and is connected to a relatively high gain input, and so is prone to picking up noise.
The tank should be installed so the output is on the right; this means the connectors will be facing away from the back of the tank, ie the tank is orientated so the output is at the opposite end to the mains transformer.
Glad it is sorted.
