Wood Butchery III - Y.A.T.B. (Yet Another Telecaster Build) DONE!
MistergMisterg Frets: 344
edited May 2014 in Making & Modding
Following on from the success of Wood Butchery I and Wood Butchery II ...
Just when you thought it was safe to.... erm... whatever... I got it into my head that I fancied having a go at making a traditional one piece Telecaster maple neck - No good reason that I can think of, just one-of-those-things.
I'm probably getting over-confident by posting this before I've finished the build, but at least a reasonable number of people will be entertained when I cock it up! :)
So it started... here...
Maple blank from ebay and headstock templates from the excellent TDPRI forum:
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/Begin_zps1ae64569.jpg
One edge planed flat and square - this will form the reference for fitting the truss rod and slotting the fretboard.
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2935_zps6eacb378.jpg
I wanted to do a vintage style truss rod with heel adjutment (again, no good reason), but I couldn't find any plans for this. There was a drawing for a Strat neck  (again on TDPRI : Factory neck drawing ):
http://img.photobucket.com/albums/v208/jwells393/Neck Building/StratNeckBlueprint.jpg
OK, it's for a Strat, but I understand that the truss rod channel is the same shape (or at least very similar)... and it's for a headstock adjust, rather than heel adjust...
The channel has slightly different start and end points for a heel adjust rod - more space is needed at the body end for the adjuster, and a bit less space at the headstock end. As far as I can tell from photos, the channel should run from just under the 1st fret to roughly between the outer pair of neck mounting screws for a heel adjust neck.
The depth channel is formed from two different curves: 255" radius towards the heel and 115" radius towards the headstock. I plugged these, and the depth of the channel at the mid-point into Excel to work out the measurments for a couple of curved rails that would vary the depth of cut along the length of the channel as I ran the router over them:
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2972_zps41b8485e.jpg
(Incidentally, I couldn't get the dimensions on the above drawing to work out - the radius and the 0.715" dimension seem to be mutually exclusive - the depth of the channel at the 1st fret works out at 0.715" with the radius/centre depth shown- YMMV)
I didn't bother making any fancy jigs, just screwed the rails to the neck blank and set about routing the slot:
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2941_zpse9718483.jpg
Cock-up number one - I wasn't holding the router tightly enough against the work on the first pass, and the router pulled off line (I also stopped the channel at the wrong mark - Doh!):
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2945_zps6b864fb0.jpg
Repair #1:
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2949_zps56019c00.jpg
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2952_zps4e458119.jpg
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2957_zpse841f475.jpg
http://i255.photobucket.com/albums/hh143/werdnayarg/webstuf/TC/DSC_2969_zps2edcdc21.jpg
«134
