Carvin belair
fastonebazfastonebaz Frets: 4091
Are these any good for Vai tones?
  • RolandRoland Frets: 8701
    Mine isn’t.
  • fastonebazfastonebaz Frets: 4091
    What are they good for?
  • Winny_PoohWinny_Pooh Frets: 7768
    Been years but they do a decent voxy/fender clean. No idea on the overdrive channel. Good value in the same style as a peavey classic 50 but a bit more portable.
    Cheers
  • Belair won’t get you anywhere near. Need to go with a full fat Legacy. Really is Vai in a box
    As @Winny_Pooh says, the clean channel sits between Vox and Fender. The overdrive channel doesn’t have the gain and compression which a Legacy has. Instead the drive channel uses diodes to put an edge on the the valve distortion. There is a modification which clips the diode, giving it a smoother sound.
    Doesn't sound like the amp for me then.  Ta
  • I think Holdsworth had a hand in designing the lead/distortion channel. I think I played through one once , about 15 years ago, and it was quite good. I think the legacy is probably what you want , tho .
