SPEAKER IMPEDENCE CALCULATOR
Thank you. I'll look for that.
booooooo!
I get better results by trying to find midi drum loops that match original recording, time consuming stuff.
I don't think anything exists that does exactly what you need, on anything other than isolated drum tracks, sorry.
if you do find anything--let me know.
The tracker functionality works really well in Superior Drummer 3, but only for direct mic'd drums (even then you have to do some mild tweaking). however, where I hadn't mic'd the hi-hat separately (ran out of mics when I did the original recordings back in 2009) I can't use the tracker function for the room mics as it can't pick out the hi-hat properly (which is why I bought that midi pad)
I'll have to find some loops that match most of it, and then learn to play the pads for the other bits.
Goody!
You can isolate the drums using Izotope RX- it is pretty phenomenal what it can do, but it is very expensive for this purpose (it is a complete suite of tools.)
If you PM me I can run the track through RX for you, then you can load it into Superior Tracker or Slate Trigger.
In all honesty though it would almost be less work to just program them.
Feedback
I did a test when I bought it on David Bowie's Heroes track.
I can remove the drums completely, other than some reverb artefacts.
Same with the vocals- you can hear some of the breath intakes but that is about it- the vocals are ostensibly gone from the mix.
If I get a chance over the next few days I'll make a couple of examples.
It is an incredible tool.
I have never done it.
