Over the past few weeks I have been practicing with an Eddie Van Halen style trem picking technique. It's actually very comfortable, for me at least, to do this with my thumb and middle finger. I'm not sure why, but it seems to be the way in which holding the pick this way slightly changes the angle of my thumb which in turn allows me to keep things more relaxed when playing.
For reference EVH hold's his pick like this:
My main problem now is synching up my left hand with my right hand. It's a little tricky but I feel it would be done with more work. Changing strings seems to be a lot easier too.
If anyone is looking for a way to try and speed up their picking then I would suggest giving this a go. I am using a .60mm nylon pick as I find it's easier doing this with thinner picks and Eddie has also used a variety of thin picks over his career.
Here is a video for
@DLM ;I find it a little harder to do on the low strings, so that's something that needs work.
I need to work on the EVH technique without my fingers anchoring I believe that's the secret to it - to anyone doing it. Once I have my wrist smooth and relaxed enough to be able to float like that that's half the battle.
Next step would be getting the technique down with a heavier pick, the .60mm is way too floppy.
How do you pick, do you use any anchoring?
https://youtu.be/oh2-Xm6M1jo
That's impressive and looks very elegant. I can't get my wrist/elbow to roll at high speed like that. But I imagine it must be tricky to control the string muting with a high gain sound.
I can only get a similar effect, beyond a certain high speed, by a vertical up and down motion from my elbow, which doesn't look pretty although there's no real tension. I've seen my method referred to as a 'Petrucci elbow spasm' approach
No idea if that will translate onto guitar!
