For Sale Bogner Duende 12w class A 1x10 combo par excellence!! £850 SOLD pending
mgawmgaw Frets: 5269
edited February 2019 in Amps £
new amp arrival means this beauty has to go, its lovely very flexible 2 channel, blendable and is best described by all of the below
Music radar says:
This is a great little amp that will inspire even the most jaded of 'seen it all before' guitarists to plug in and play for hours. It's portable, it sounds great at low volume, terrifyingly awesome when cranked and it's got nearly everything most players could ask for in the way of features……..Very tweed and very Deluxe in character, very responsive and a delight to play from the second you plug into it, the Duende had us hooked with its great tone and friendly response. Swap to humbuckers, and from Royal Scam-era Larry Carlton to Billy Gibbons or David Grissom, the Duende can get you exactly the right tone for practically all those rhythm and solo parts.
The Bogner DUENDE 12-watt, 1 x 10" tube combo amplifier puts all the features of the "big" amps into a lower-power combo that's perfect for studio work, rehearsals, smaller stages, or playing at home. The DUENDE offers two channels, each with it's own dedicated reverb control. You get crystal-clear clean tones, tasty mid-gain crunch, and even high-gain sustain from this amp, but that's just the beginning: you can combine the channels for even more amazing tones, and the addition of great-sounding onboard tremolo and reverb only adds to the fun.
Incredible playing experience:
The DUENDE puts out 12 watts of rich tube tone from its pair of 6v6 power tubes and five 12AX7 preamp tubes - a solid foundation for a feature-packed amp! This portable unit's clean channel can take you from pristine to crunchy tones, while a second channel delivers higher gain tones with tight lows. You can combine both channels for a stellar combination of American and British amp characteristics, giving you a truly exhilarating playing experience. Top it all off with shimmering reverb with independent levels for each channel, and a tremolo with speed and depth controls. Want even more? The DUENDE also includes a tube-buffered effects loop and compensated recording output for directly connecting to mixers and recorders. All this from a very compact amp that's easy to transport to the studio, rehearsal, or gig.
The man behind the amps:
Though Reinhold Bogner began designing and building amplifiers long before leaving Germany for the U.S. in 1989, his career really took off soon after arriving in Los Angeles. He quickly gained the trust of many influential players, including Steve Stevens, Dan Huff, Allan Holdsworth, Mike Landau and Steve Vai, who sought out his skill at modifying and custom building their amps. Eddie Van Halen entrusted Reinhold to overhaul and revitalize his number one Marshall Plexi, with great results. Soon after, Bogner Amplification was born, and the rest, they say, is history.
Handcrafted quality:
Bogner amps are handcrafted, using only the finest components available. When you plug into a Bogner, you're not simply getting premium tone; you're getting the value of a piece of gear that's made to be played for years to come and built to handle the rigors of the road. From speakers to pre- and power amp designs, cabinets to cosmetic touches, Bogner amps are built to give you the best, most reliable playing experience, period.
Bogner DUENDE 1 x 10" 12-watt Tube Combo Amplifier Features:
12W 1x10" combo
Two 6V6 tubes
5AR4 tube rectifier
Five 12AX7 preamp tubes
Two channels that can be combined or used separately, footswitchable
Reverb with independent level controls for each channel, Accutronics Spring large tank
Tremolo with speed and depth (pull on) controls, footswitchable
Effects loop tube, buffered send/return
Power amp line output
Master EQ section: Air (Treble), Body (Bass) controls shared with Channel 1 and 2
Channel 1: Gain (Pull Bright), Treble, Bass, Volume and shared Master EQ controls
Channel 2: Gain (Pull Gain) , Volume and shared Master EQ controls
The Bogner DUENDE packs amazing tone and features into a compact, all-tube amp!
plenty of hyperbole but generally true   and yes the bottom half of the g has fallen off and yes you could say it spells boner and yes I have contacted Bogner to ask for a replacement
  • mgawmgaw Frets: 5269
  • ZoolooterZoolooter Frets: 886
    Beautiful amp, got to be the bargain of the year so far at that price. I have a New Yorker which is brilliant. An amazing amount of amp for £750!
    I have no affiliation with the seller, just commenting.
  • dallcorpdallcorp Frets: 139
    Pm sent
    pm replied
    Price upto £850 to include nos valves
  • Whereabouts are you based? Apologies if it’s in the above text and I’ve missed it...
    north cornwall/north devon border
  • Brilliant amp at a bargain price....and rare...try and find another one....GLWTS
  • ExorcistExorcist Frets: 604
    PM'd
  • BarneyBarney Frets: 616
    Are you looking to trade at all ?
    @Barney maybe but £1000 trade value
    @Exorcist pm replied to still for sale folks
