I used a capo recently as I was feeling lazy and didn't want to play in B Flat and I noticed the instrument seemed to sound better somehow, and easier to play. To check it wasn't just the elevated pitch, I tuned the guitar down a semi tone then capo on 1st fret again so it played at standard pitch, and it still sounded better than normal.
Is this likely to be that an adjustment to the nut is required?
Hard to describe the difference but the low strings were less boomy, the B string stayed better in tune ie between open and tuned there was less difference somehow.
Thanks
soundcloud.com/thecolourbox-1
I also play flamenco guitar, which is a style of play where players use capos and the lack of fretboard/neck markers do actually make it a little less confusing than having fretboard markers on a steel string guitar.
