I have an Epiphone Casino ('97 Peerless Korean). I've had the guitar setup and modded and I love the look and feel. The original pickups were terrible, very high output and muddy, so I had them rewound giving a lower output. This improved things a bit but the guitar still sounds dull, particularly the neck pickup. I've even tried experimenting with magnets - the neck now has an Alnico II/V combo.Thinking the problem might be the metal cover. I've just recorded a quick comparison (just some open chords and a brief single note line). In each case, the UNCOVERED pickup plays first and is panned left the COVERED pickup follows and is panned hard right. The recordings are run through identical amp/eq sim settings (Amplitibe Fender Twin model)
To me there's a world of difference. The uncovered pickup (while noisier) has much more top end. It's noisier (covers shield noise I think) and louder too (this might be a difference in playing but I tried to use the same force each time). The covered pickup sounds very dull in comparison.
So, eventually, here are my questions:
1. Do other people hear the same difference, or has this guitar finally driven me insane?
2. Would replacing the metal pickup covers with plastic ones keep the same treble content as an uncovered pickup or would this still attenuate the high frequencies to some degree?
Sorry for the long post but this has driven me mad for a year or two. I have other guitars with humbucker, P90 or single coils and the Casino is easily the dullest/boomiest sounding. I realise that some of this is the hollow body resonance but it still seems extreme. I can't get plastic covers to replace the metal ones as the Casino neck dogear has narrow string spacing. I would probably need to buy a complete replacement set, which I'm happy to do but want to be as sure as I can that it is the metal covers causing the problems.
Thanks for any thoughts/opinions.
The other problem I have discovered from dissecting several Casino pickups ... is that they use 43awg (instead of 42awg used in a proper P90) in order to fit all the wire onto smaller than standard bobbins. This means you can't really rewind them with the 'right' wire, as it won't all fit! 43awg wire can lack treble in some winds ... particularly machine ones with no scatter ... so the problem is pretty much unresolvable with those bobbins.
What GuitarWeasel, ChrisMusic and GuitarMonkey said.
You're not the only one, there is a big difference, and plastic covers will sound the same as no covers.
I like metal covers on some pickups (sorry Ash! ), but they do definitely alter the tone - more with some pickups than others, and also dependent on the metal type and thickness of the cover. In my opinion, the 'softer' the magnetic field, the bigger the effect - eg Alnico II pickups are affected more than Alnico V, and ceramic least. A P90 also has a pretty diffuse field due to its construction. A thicker or brass cover has a bigger effect than a thinner or nickel one. I could be wrong but I think Epi Casino covers are plated brass - they're definitely very thick though.
Hadn't thought about Mojo. Have heard good things about them.
I seem to remember the neoprene thread and I'll search it out. I've done this before with the foam off an old mousemat but it's not easy to cut cleanly so the results were a bit ragged! I think the chap who used neoprene bought sheets of it off ebay. I guess the ideal is something dense enough to cut easily while still conforming to the arch. Interestingly enough this appears to be the material that Rickenbacker use, at least it is on my 660.
If you want a 47.2 cover to try ... I'm happy to send you one.
Ash
