Need your wisdom folks.
I have never actually tried to run 2 cabs before and just wondering the best way. It is a DR Z Maz 18 and going to try running it through a 2x10 and 1x12. Just to see how it sounds. Both would be 8ohm I think
Is it just a case of getting some sort of Y cable and plugging to both, then into the 4ohm output on the amp? If so, any ideas where I can buy such a thing as initial search didn't throw up much? Would like to buy a decent quality one if possible.
And anyone tempted to suggest me making something, don't. The only thing I would have confidence of me making, is a complete arse of it.
If neither of your cabs has that (only one needs to have the second jack socket), I've seen the thing you want on the award session site.
http://www.award-session.com/cleartone_specials.html (scroll down to "Speaker Y Splitter Cables")
If you can fit a 13A plug (and as an adult you should be bloody well ashamed if you can't!) you can cut and splice two speaker cables to make a Y lead.
You could "twist and tape" it (ugh!) or use 5amp electricians "choc-block".
If you really are that helpless, try our very own Kabl kables.
Dave.
http://www.kablonline.com/
For some reason I can't insert a link via "edit"?????
Dave.
"I would definitely not recommend twisting and taping wires to make a speaker cable for a valve amp! "
^Hence the "UGH!" It is in fact quite possible to make a very good taped joint but I would only do it in extremis and NEVER for mains! (well, maybe to get a kidney machine running??!!?)
Yes, like the smoking ban, the lives saved from the introduction of moulded mains plugs is incalculable. I was "there" at the start of the debate and just like the minimum wage, all the greedy bastards said it would cause the collapse of civilization as we know it!
But peeps SHOULD still know how to fit one properly!
Dave.
Thanks fellas.Very helpful advice!
I can change a plug, but still don't fancy taking it on myself...
So with that in mind, @RobDavies are you out there?
(Could you knock me together one of the aforementioned Y splitters to run 2 cabs. And will also need another 1m Speaker cable, right angle to straight plug. Have PM'd my email address to send paypal invoice to)
Will be interesting to see whether one cab overpowers the other and makes it all rather pointless. The 2x10 is Dr Z's own 10" speakers. And the 1x12 is a Creamback. I can't imagine it is going to sound bad anyway.
These are very loud beasts for 18 watts. Have had other 18 watters and this seems double the volume.
I'm pretty sure My Maz 38 has more than 1 speaker out
God knows how loud the Senior is.. The 18w is ridiculous.
Re. the Y cable. I am just going for a smallish thing, with one male for into the amp, and 2 Female plugs. Then the Speaker cables go into that.
Hopefully will work ok. Very very rarely play out anywhere, so the Y cable won't be tested too rigorously.
"Re. the Y cable. I am just going for a smallish thing, with one male for into the amp, and 2 Female plugs. Then the Speaker cables go into that."
DO NOT! Tell me that you are contemplating using female jack adaptors????
These are almost universally cak! They go intermittent and could damage a valve or worse.
The ONLY one worth a light is the H duty locking jobby from Neutrik.
Dave.
Too late guys!
I think Rob may have already completed the Y cable and on it's way. But he did say he was using Locking Jacks, so may be not the end of the world...
Any additional precautions I should consider? Like I said, chance are it won't be moving anywhere, so should hopefully limit any issues.
@ICBM No idea if it has the ring connection grounded, but hopefully won't be an issue.
Only had chance to give a quick blast when I got back from work, before kids to bed etc..
Hard to make a decision on how much I like both running together, as it has added considerable volume and bass, so I need to re-dial everything back in to sound the way I want, which takes time on the Maz as all the controls are VERY interactive.
Will report back tomorrow.
