An interesting look into the different versions of the Xotic BB Preamp pedal.
equalsqlequalsql Frets: 6165
edited April 18 in FX
I built my own BB preamp clone a few years ago and to this day I've yet to find an overdrive pedal that I prefer to it, and lord knows I've been through many pedals. I built mine using the instructions on the tagboardeffects blog:
https://tagboardeffects.blogspot.com/2012/10/xotic-bb-preamp.html
Anyway, whilst looking back on information about this classic pedal I found the following article that details the circuits used in the different versions of the pedals that were released, including the Andy Timmons model.
Definitely worth checking out if you're a fan of this classic preamp.
https://aionfx.com/news/tracing-journal-xotic-bb-preamp-five-variants/
When I built mine I had to a parallel up quite a few capacitors to achive the correct values and I don't know if this added some mojo vibe to my build cos it sure sounds great.
Any BB fans on here?
  • bobeffectbobeffect Frets: 57
    Yes definitely. The custom shop version with mid boost. Really versatile pedal with a 3 band eq.
  • LittlejonnyLittlejonny Frets: 140
    I have the Caline Orange Burst. It definitely has some magic to the midrange. Very sweet sounding drive. I don’t like it with the gain past 12:00 because the distortion sort of separates from the clean bleed through, but then I always play with a completely clean amp.
  • GreatapeGreatape Frets: 3605
    I have the BB Comp. It's pretty cool, especially for home use. That AT setting drops volume but adds a lot of crunch.
  • TimmyOTimmyO Frets: 7555
    The BB-MB is a REALLY good pedal. The mid.control.is very nicely tuned
    Red ones are better.
  • thermionicthermionic Frets: 9671
    Interesting that all the diy clones diverge from the actual circuit.
    Can it dial out some of the baseline midrange, or is it just a boost ?
    Yes, iirc 9 o'clock on the mid control is the default mid setting on the regular pedal, so you have some 'cut' from there as well as (more) boost.
