Hey folks
This may get a bit "stream of consciousness" but hopefully won't ramble on too long.
My main (only) electric guitar is a Schecter Corsair, which is a fairly classic-styled semi-hollow double cutaway guitar with two coil-tappable humbuckers (they're "duncan designed" pickups based on the SD '59, apparently). Big heavy mahogany centre block. 34" scale.
Now, this guitar isn't going anywhere. Its a great guitar and even if I wanted to sell the resale is so bad that I just wouldn't. Thing is, I've never *really* been a humbucker guy. They're just a bit...I dunno. Too middy or dark or something.
So, I'm thinking about putting (humbucker sized) P90s in. Probably Irongears or something from GFS. But I don't know if I should or not---do you think I would lose versatility by doing this? I'm not a tone-hound by any stretch of the imagination, at the moment I can use the coil-taps for single-coil-esque sounds and if I ever actually need humbuckers they're available. Would it be worth the hassle of going through the rewiring process on a semi-hollow to do it? Should I leave it alone and just play the damn thing?
The other thing is, I never really use the bridge pickup. This is true of all the guitars I've ever owned---I'm normally either on the neck or the middle position. Bridge pickups tend to be a bit too brittle and sharp for my liking. Would putting a P90 at the bridge make this even worse? Would anyone recommend anything other than a pair of p90s?
In terms of sounds, I'm into indie rock / post rock / funk / punk / reggae / indie pop type stuff. Classic rock isn't my thing at all and I very rarely play "lead" guitar, I'm just not a widdly-widdly guy.
Thoughts please...
If you want to change the neck pickup to something that you think will be more suitable for you, then go for it! A neck p90 is a great tone.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Feedback
From last night's youtubing I think I'm really tempted by some kind of filtertron.
However, that said, I think at the moment it would cost more than I'm prepared to spend (£120 for those mojos plus good quality switch /pots /jack /caps). Plus I'd need to buy a soldering iron and find the time to do all the work!
So perhaps I shall hold off just now and wait till I can do the job "properly" - I don't want to do this more than once!
This was kind of a long term project but hit me up if you're definitely selling, the worst that happens is I say no!
