Repairing Ibanez RG470 neck (pictures)
cruxiformcruxiform Frets: 2567
edited April 2015 in Making & Modding
I've been meaning to do this for ages but just got round to it today. Following the excellent tutorial at the Ibanez Rules website, I have managed to make a start this afternoon. My RG470 was made in Japan in 2002 and is a great guitar but the crack on the neck has always bugged me. It happened when the guitar fell over years ago. First thing I noticed was that it appears that Ibanez used the neck from the RG550, which is no bad thing:
This is the crack, which is difficult to see:
However, it becomes more apparent when a clamp is used to open it up a bit:
I filled the cracks with loads of wood glue, making sure it all got in there with the use of my expired fishing licence :)
I knew I had put enough in there as when I released the pressure was released from the clamp, it squidged out of the sides like a good 'un. I wiped away the excess with a damp cloth:
Some more glue came out when I attached the clamp again, and I wiped off the excess again:
I'm going to leave it (attached to our dining table!) for 24 hours, then I'll start the next stage of sanding. All going well it should be a good repair.
  • FuzzdogFuzzdog Frets: 839
    Exactly the same place my MIJ S series cracked at - bit of wood glue and a good clamping, it never opened up again despite falling over a couple of times after, so you should be good. :)
    -- Before you ask, no, I am in no way, shape or form related to Fuzzdog pedals, I was Fuzzdog before Fuzzdog were Fuzzdog.  Unless you want to give me free crap, then I'm related to whatever the hell you like! --
  • cruxiformcruxiform Frets: 2567
    That's good to hear, thanks for that.
    edited April 2015
    I actually took the clamps off yesterday evening and the glue seems to have done its job. A bit of sanding to blend the repair:
    Then applied some tung oil. Job's a good 'un!
  • DrBobDrBob Frets: 3006
    Good work man !
    DrBob said:
    Good work man !
    Thanks, new strings and setup to be done this morning then it may well become my number one guitar again :)
  • That looks like a job well done mate. Gonna give you a 'wow' not only for the quality of repair but managing to use your kitchen table...you must have a very understanding partner!!!
      She's used to it, bless her :)
    Ready to go. Can't wait to try the Dimarzio Tone Zone/Air Norton combo through my Marshall.
  • GizmoGizmo Frets: 1078
    Nice job,Kind reminds me of what an Airline did to Vai's Bo ibby and how it was repaired.
    http://guitarnoize.com/airline-smash-steve-vais-guitar-bo/
  • octatonicoctatonic Frets: 33825
    edited April 2015
    What glue did you use?
    Looks like Evostick wood adhesive.
    Yeah, that one. Don't tell me it's going to fall apart!
  • WezVWezV Frets: 16748
    It will be fine. Titebond original is better but ordinary wood glue is still pretty strong
    It will probably be fine.
    Titebond is better.
    The problem with PVA (even 'modified PVA') is it can flex.
    Some luthiers look at PVA as the work of the devil.
    It isn't ideal but it isn't as bad as people make out either.
    Thanks guys, Titebond will be used for any future repairs!
    No worries, I prefer Titebond 'original' fwiw.
    They are all pretty good except for the Titebond 'Liquid Hide Glue' which is pretty useless.
    if you do, make sure it is titebond original.   I remember advising someone to get titebond and they turned up with Titebond 3 - because 3 is better than 1 right.  not sure why they though being waterproof and suitable for exterior use made it better for guitars???
    Playing festivals?
