Westbury Standard gettin nekkid!
SargeSarge Frets: 2370
edited December 2019 in Making & Modding
Started off like this
Wine red, with plenty chips and dings which I drop filled a few years ago.
I fancied doing this for a good long while now, but waited until I got another Standard in, just incase I balls this up!
So...
Heat gun check!
Paint scraper, check!
Suitable Japanese mahogany bodied rock monster?.......check!
https://photos.app.goo.gl/WmBcD7d56k37jHXy5
Gently heated the finish with the gun, keeping it moving at all times, and NOT letting the finish bubble/burn.
eased the scraper under starting with a couple chips for easy access.
https://photos.app.goo.gl/m6iaoHJgrFzdURHC7
it all came off in about 20 minutes, a far cry from using the elbow-shaking palm sander!
after a light sanding with 240/320 and 400 grit we are all systems go!
https://photos.app.goo.gl/4iGPeXFTXvLXtD3R9
https://photos.app.goo.gl/b7bN1amm2Pv3BnmT6
https://photos.app.goo.gl/tpVyzKirx2yKGpeG7
This is after just one coat of Tru-Oil, I was going to try @Wezv's method of wet oil sanding but I'm running low on oil and this mahogany is finished really well so shouldn't need many slatherings, 5 or 6 should do it, oil permitting.
https://photos.app.goo.gl/Z3EZGk8EeZFDWtHk6
https://photos.app.goo.gl/5Potsuhf7uRVnmu76
https://photos.app.goo.gl/a4yiNdcnuch4FayZ7
«13
  • koneguitaristkoneguitarist Frets: 4125
    Looking nice, always loved these.
  • John_PJohn_P Frets: 2744
    I'm amazed how the finish came off like that - nice work!
    It looks a lot nicer now - should be a cracker when it's finished :)
  • SargeSarge Frets: 2370
    Well I always liked the trans red/wine finish on these, but when there's all that vibrant mahogany underneath, well... It would be remiss of me to NOT reveal it :)
    This came to me with a pair of lethargic epi pickups which did absolutely nothing for it, so I put a pair of late 70's dimarzio k10's in it, wowee! Those pups just compliment the dark of the mahogany so well.
    That finish has come off fantastically well :) Lovely wood underneath, too!
    The heat gun was my only option really, no way was I going to spend all fathers day sanding that French carve!
  • usedtobeusedtobe Frets: 3841
    That's stunning, sarge!
  • TTonyTTony Frets: 27345
    That's a nice piece of mahogany 2-piec body (the centre join is difficult to pick out).
    For what was a relatively budget-priced guitar, that's some quality!  Much better without the paint on it.
    Gahh, I spent all evening rewiring it 50s style, or at least that was the intention, I've obviously ballsed it up somewhere along the way as I've got no volumes but 3 tones and a something!
    I hate wiring with a passion!
    Think I'll cut my losses and purchase a wiring loom to drop in, sod it.
    Before you do that - and now you've had some sleep! - just follow each connection and wire run carefully against the wiring diagram. It's usually something simple missing or cross wired (and in my experience, usually involving the earth wires!)
    I'll do that, thanks.
    It's a bit blurry but I think I've got a spare lug on each tone pot, probably should run to ground....
    The tone pots generally do have an empty lug. The pots are grounded with the earth wire on the back of the casing. What wiring diagram are you using?
    This one
    http://www.guitar-mod.com/images/lp/LP_50s.gif
    I'll get back to it after work this evening.
    So there's nowt wrong with this diagram is there?
    I suspect I may also have a burnt out capacitor, the lug is dangerously close to the cap itself and it took a few goes getting the solder to take, maybe a little too hot.
    The diagram looks fine. Have you followed each earthing point to make sure they ultimately are all connected to the Jack ( including the earths from the pickups )? Do you have a multimeter to check earth continuity?
    Yes and yes, but have not checked with the meter yet.
    I had a quick 10 mins poke around and I'm going to have to replace pretty much all the wire, I have some 22awg cloth covered to go pot to pot etc. but need to buy the rest.
    the whole things a mess really so I'll stop farting around and do it properly.
    I have plenty of signal fully open so I'll make do for now.
    A pair of old Hondo Dimarzio K-10 and some amber numbered knobs.
    also sprayed the position markers black to tidy em up a bit.
    https://photos.app.goo.gl/vytbADcbw8SnMSzt9
    https://photos.app.goo.gl/jAYX5P5TpcJLWSSB7
    ....and just because....
    https://photos.app.goo.gl/cN6sRrFfFaoQvfyB6
    https://photos.app.goo.gl/4LcpSX8WDzHSz3B5A
    edited June 2015
    Thanks for the help @Andyjr1515 it's much appreciated :)
    OK I FINALLY found where I was going wrong, apart from 1 dead capacitor, the spare lugs on both volume pots should have gone to ground, even though the diagram clearly indicated so.
    Schoolboy error!
    I swear I'll never get my head round this leccy malarky.
    Ive got it all to do again as I've just pulled the trigger on a HB goldtop and a pair of vanson '57 alnico II buckers and I want to get the magical wiring from my Westone prestige 250 in it: both tone pots are unique to matsumoku wherein they are center detent, anti clockwise it's standard tone, and clockwise it's a variable parallel to series, or vise versa.
    Nightmare!
    Actually I changed my mind at the last moment, instead of the Vanson '57s I went with the Axesrus Knee Jerk Basic AlNiCo II 2 conductor set instead, so something of a simpler soldering session.
    Dodged a bullet methinks.
  • Flanging_FredFlanging_Fred Frets: 3010
    Wow, it looks really great! Now that I have appeased Mrs Fred and sold a few guitars so that she didn't totally freak out when I bought my Gibson R8. How many months do you think I should leave it before 'accidently' buying another Westbury? :)
    Thanks!
    You shouldn't even wait a month, in fact I've a lovely black one with a recent fret dress/cut polish and a coil rewind I might not have a use for ;)
