Excellent condition, compact and portable pro combo.
Don't be fooled, this kicks out a mighty loud 20w,of valve goodness.
Item is flightcased so well protected for whatever you can throw its way.
Includes power lead and 2 button footswitch
Amp controls include 4 band EQ (Bass, Mid, Treble and Presence) plus independent controls for Gain and Volume for each of the 2 footswitch-able channels.
There is also a switchable contour mode which re shapes the drive channel, giving you 3 separate tones to play with.
Parallel fx loop and speaker outputs to connect to an external speaker cabinet if you choose to do so.
Recording output.
Perfect for home use, studios and small to medium venues.
The clean channel is a great platform for pedals.
Based in Dersingham, Norfolk but can travel to Norwich, Peterborugh and neighbouring cities if needed.
£500 ovno or will trade for Vox AC30.
